Question about HP Tablets & eReaders
Free unlock pattern code pendo model pp4mt-7 - HP Tablets & eReaders
How do I claim my free Pendo tablet?
ask the vendor or service provider
Jan 31, 2016 | Tablets & eReaders
Pendo 4.0 7 inch android ics keeps rebooting and freezing, how do i fix?
If the problem started right after the rooting/flashing custom ROM you'd better get back to official ROM then follow up carefully instructions "how to root" and use proper ROM.
Feb 09, 2015 | Tablets & eReaders
How do I unlock
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Jul 04, 2014 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
PATTERN LOCK PROBLEM
If you have forgotten your lock code you can try default codes like 12345 or 0000 or 01234, if it doesn't work you can reset your phone with the help of Unlock-Free.com where you need to mention your phone model and IMEI number...
Note:They provide master reset codes (free) for old models of Nokia and Allcatel.. Unlock Free com
Mar 04, 2014 | Tablets & eReaders
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Mar 08, 2013 | Tablets & eReaders
Forgot the pattern code on Polaroid tablet 7
i forgot my tablet pattern unlock what do i do
Dec 26, 2012 | Tablets & eReaders
Pendo pad tpc7slv to unlock sign but wifi not working how can i connect
i cannot open my pendo pad tpc7slv because it was locked and i dont know how to open it.how to reset it without wifi connection
Nov 29, 2012 | Tablets & eReaders
How to unlock pendo pad model tpc7slv
Unlocking your Pendo Pad is easy, if you forgot your pattern code. Just keep putting in wrong patterns, you need to do this at least 20 times, sometimes you will be unable to continue for a few seconds after 5, 10, 15 attempts,but just wait it out & keep going. Eventually it will ask you to enter your Google email & password & Bingo, you`re back in!!
Aug 28, 2011 | Tablets & eReaders
Tablets & eReaders Logo
Top HP Tablets & eReaders Experts
Lawrence Oravetz
ka4iup
ka4iup
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
