Question about Kitchen Appliances - Others
Hello i have a Breville country cooking system,(country kitchen and dutch oven)but my thermostat control blew up the other day ,now i have had this set for many years,beautiful to cook particularly steak and roasts and cassaroles.Can you please tell me where i can get a new thermostat control? Much Apreciated G.P
  • Anonymous Apr 14, 2009
    HELLO DOES YOUR UNIT HAVE A DETACHABLE ELEMENT BASE THAT ATTACHES TO EITHER PAN, I AM LOOKING FOR ONE OF THOSE I HAVE AN ELEMENT BUT NEED A NEW BASE
A Kambrook KD66/01 control will do the job.
Is a little tight fitting but works fine.
Great frypan, dont know why Breville stopped selling them.
Posted on May 10, 2010
What do I do if my Breville Bakers Oven is shorting out the electricity in my house
you may find that on cook that it may be using more power than your switch is rated for .it might only be say a 10 amp power point but when unit goes into cook mode it may need a 15 amp power point - i really dont think this is why -maybe there is a fault in the unit -if so see if you can google breville bakes oven and see if anyone else may be having problems or ring breville themselves
Aug 07, 2014 | Breville Bread Maker BBM100
What is the best shape for a dutch oven?
The best kind of Dutch oven to invest in is one that is round and wide. It should have sides that are more straight than sloped. This is in order to have a lot of room for searing/browning. The oven should be 4 " deep.
Oval dutch ovens will cause the food at the ends of the oval to cook unevenly when searing. An oval oven is good for pot roasts and whole poultry.
May 01, 2013 | Home
Frigidaire cookstove model no. fgf316wgta oven not getting hot enough
Hello - Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
Sep 25, 2012 | Frigidaire Kitchen Ranges
My oven stays at 150 degrees at all times...even
clean pilot assembly. then oven thermostat
Jan 01, 2010 | GE JGBS20 Gas Kitchen Range
No broil or oven cook top works
try checking the ignitor or the thermostat in the oven.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool gas oven shuts down after cooking for extended periods
id like to see it happen bfore replacin parts, but the control panel is the only "control for bake" there is no "resetable thermostat", and it uses direct spark , not an ignitor( usual suspect)..perhaps after long heating the relay on the control heats up and doesnt close correctly
Jan 20, 2009 | Whirlpool SF367 Gas Kitchen Range
Kenmore range control panel not working
sounds like the control board blew on you replace it.
Dec 16, 2008 | Kitchen Ranges
Oven modelakz 1467 type fcew16 pre heat works but will not heat up after that grill is fine oven u/s
if it isn't cooking, the most likely cause is the door seal is not sealing, though the thermostat control may be bad instead, if the oven cooks, but can't be used to set the temperature or the timer if you can't set cooking time.
Dec 05, 2008 | Whirlpool Kitchen Ranges
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Kitchen Appliances - Others Logo
767 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
