Question about Zoo Med Zml Lamp Avian Sun Dlx Floor -
Lamp #GX9906 failed
Electronic box in lamp base--repairable?
No fuse is labeled for interior lights. Which one is it?
My thought would be room lamp, 15 amp. Interior fuse box.
Dec 16, 2017 | Mercury Cars & Trucks
The electronic circuit broken, lamp doesn't work
listed under air purifier,send to manufacturer
Jul 01, 2015 | Air Purifiers
2002 ford expedition interior lights are not on what fuse is it?
Courtesy Lamps - central junction box. fuse # F1.21 that goes to interior lamp relay in the instrument cluster and F.24 this fuse powers battery saver relay .
Interior Lighting The interior light system consists of the following:
  • front map lamp assembly
  • front door courtesy lamp
  • generic electronic module (GEM)
  • glove box lamp assembly
  • central security module
  • interior lamp switch
  • interior lamp relay
  • illuminated vanity mirrors (Navigator only)
  • reading lamp assembly
  • rear courtesy lamp
  • running board lamp
  • underhood lamp assembly
  • The generic electronic module (GEM) illuminates the interior lamps when an unlock signal is received from the remote anti-theft personality central security module. The illuminated entry feature will be canceled when any of the following conditions are met:
    • 25 seconds have elapsed since the illuminated entry feature was activated and the interior lamp control is not activated (door ajar or courtesy lamp switch on).
    • The GEM receives a request from the central security module (remote transmitter lock button pressed) and the interior lamp control is not activated.
    • The ignition is in the RUN or START position and the interior lamp control is not activated.
    The GEM will illuminate the interior lamps when any door is open or ajar. The interior lamps are; the dome lamp, the rear cargo lamp, the door courtesy lamp and the side rail lamps. The courtesy lamps will shut off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps will not be reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp switch is received.
    The GEM controls the interior lamps illuminated entry function by activating the interior lamp relay.
  • You have an electronic control module and relays involved in the operation of these lights also !
  • What
    Jan 08, 2015 | 2002 Ford Expedition
    Dlp tv color goes fuzzy and green
    Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
    Dec 14, 2013 | Samsung Televison & Video
    Wd52525 when powed up set tries turn on. it tries for 2min then powers off with the red led solid at shut off
    Most probable a lamp failure, part number according to encompassparts.com is 915P020010.
    https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6543337&smodel=WD52525
    I have had issues also with the power supply having failed capacitors, tops of caps will bulge up rather than be flat. The most common failure is a popped lamp or defective lamp. Inspect the anode of the lamp, it may have fractured or is swollen at the base.
    I buy lamps on line from a company called niosales NEIlamps and electronics.com
    Jul 12, 2011 | Televison & Video
    My LCD projection tv(KF-50E200A) displays projection lamp week when switched ON and out of red color display on the screen. Is this will happen if the projection lamp is week?
    no and yes
    the lamp warning is to alert you that a timer has expired that clocks the approximated life of the lamp in "hours of use".
    it is never accurate and is dependent on whether or not it was reset the last time a lamp was replaced.
    reset the lamp timer in the users "setup" menu.
    the lamp has NOTHING to do with color, it only provides light.
    check the connections between the TV and cable/satelite box...the red.green.blue component connector...the red one is likely loose.
    if this does not correct you color problem, your optical engine has failed.
    very expensive repair, not for the DIY type guy.
    Apr 17, 2011 | Sony KF42E200 TV
    Infocus projector won't turn on
    From the infocus_lp650 manual
    Table 2:
    Red LED Behavior Explanation
    One (1) blink The lamp won't strike after five (5)
    attempts. Check the lamp and lamp door
    installations for loose connections.
    Two (2) blinks The lamp counter hours have exceeded
    lamp life hours. Replace the lamp and
    reset the lamp hours counter.
    Optional Accessories Part Number
    Three (3) blinks The projector has shut down the lamp.
    Replace the lamp. Contact Technical Support
    for repair if replacing the lamp does
    not solve the problem..
    Four (4) blinks The fan has failed. Replace the lamp (the
    lamp module contains a fan). Contact
    Technical Support for repair if replacing
    the fan does not solve the problem.
    Five (5) blinks The projector is overheating. Check for a
    blocked air vent. Contact Technical Support
    for repair if clearing the air vents
    Jun 18, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Output light dimming and brightening
    This is caused by a faile color wheel sensor. This is like a strobe signal and the projector controls the lamp with this signal. When the sensor failed, you get random noise and the lamp control circuitary is going crazy. This is a known problem with the VP63XX series of projectors. I am factory trained and I can fix the problem for you. If you are very good with electronics, I can sell you the repair parts plus instruction.
    Mar 03, 2008 | HP vp6320 Multimedia Projector
    Zoo Med Zml Lamp Avian Sun Dlx Floor - Logo
    124 people viewed this question
    Top Zoo Med Reptile Experts
    windryder
    Level 1 Expert
    john h
    Are you a Zoo Med Reptile Expert? Answer questions, earn points and help others
