Question about John Deere 4020 Gas & Diesel Tractor Radiator
John deere 3020 wont start when warm
Starts great when it is cold, but will not restart after I have been running it awhile and shut it off
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
  • 9 Answers
SOURCE: john deere tractor won't stay running
Its using up the gas in the carb then it stalls. take the carb off and clean it and make sure the float in the bulb of the carb isnt sticking closed.
Posted on Jun 22, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 5 Answers
SOURCE: My John Deere lawn tractor
If you have a fuel solenoid switch on the float bowl you can remove it and replace it with a plug. You can leave the plug disconnected. Did it to mine and it runs better than ever. I think the solenoid get s hot and shuts off the fuel
Posted on Aug 01, 2010
I have a john deere 997 ztrax ride on mower starts ok runs for about 10minutes then cuts out starts again runs for 5 minutes then cuts keeps doing itout cannot find the problem it is a 2004 model
Have you given it a tune up and oil change recently. If not,mdomsomand then see how it runs. If you are still having this problem, it could be the coil,having problems once it warms up. A good clue is, will it restart right away after it shuts down. If it won't, then it's probably the coil. If it does start up when warm, it's possible the fuel pump may be acting up.
Oct 27, 2017 | John Deere Garden
Remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
My John Deere lawn tractor starts and runs ok but sputters and quit after usinng a short time and then is hard to restart. Putting gas directly into the carburator and it starts right away.
Jul 31, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Starts good runs good on idol, but under load misses
Is it a lp,gas are diesel?...If lp are gas check timing and point are in some cases the flapper in the carberator.If Diesel it possible the flex ring is coming apart in the injection pump and stoping up the return lines at the injectors retarding the timing advance in the injector pump..very common in the 3020 4010 4020 4320 and 5020 John Deere ag tractors...
May 16, 2010 | John Deere 3010,3020 Tractor Basic...
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
John Deere 4020 Gas & Diesel Tractor Radiator Logo
114 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
