My studiomaster Club2000 mixer has both the level meters showing full value always.The mixer is working ok otherwise changing the display ics LM339 doesnot help.I require the schematic for this.Can someone help
  • Chellakumar Valentine
    Chellakumar Valentine Mar 13, 2009
    Master:
  • 497 Answers
Http://www.dabluntnet.plus.com/docs/Manuals/studiomaster2000.pdf
i dont know if this wud help..
Thanks for using Fixya
Have a nice day!
Posted on Mar 13, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Service Manuals and/or schematics are available here or here for a fee.
Incidentally, have you traced the inputs of the LM339. In most designs, there would be trimpots used to calibrate 0 signal level.
Good luck and thank you for using FixYa.
    Sergeant:
    Champion:
  • 435 Answers
Hi, I think you have posted in the wrong section.  Anyways, Can you be more specific about the problem?
thanks,
Posted on Mar 11, 2009
No meter level on ipad when connected and powered up
Disconnect and reconnect the Ipad from the mixer. It should sync itself up and meters and levels will reappear. Also, you can go to SHOWS, and select the DL808 mixer under Wired Connection and it should sync up, as well as tap on the CONNECTED icon at the top left of the screen.
Feb 13, 2014 | Mackie Dl806 8-Channel Digital Live Sound...
Color convergence
find the change value capacitors and resistors in the convergence section!
Oct 08, 2007 | Toshiba TP50G60 50" Rear Projection...
I have a studiomaster vision 8 powered mixer the
Probably you have a missing voltage at power supply which should be +15V/-15V connected to a number of opamps in the mixer section of the circuit, NOT in the power amp section, let me know to help troubleshoot your issue.
Nov 01, 2013 | Audio Players & Recorders
I have a studiomaster proline 1648 gold mixer, when i input stereo out from my pc into 2 channels. the out put is 2 xlr to amplifier speaker. but the sound is only one side (either left or right). i have...
Pleas check which side of the cable does give you sound. Lets say the red RCA line works with the right speaker. Now swap the wires at the back of your mixer ie. change the red plug to the white input on your mixer. If no sound comes through, your mixer might be dead on that channel.
Jul 16, 2010 | Audio Players & Recorders
Microtek flatvision display horizontal continuous moving.
that is problem of diode near EHT that diode connected to big heat sink having three leads two series diodes in one diode replace it even meter shows ok .If persists then check mosfet irf 630 and path of its gate touch heat sink if it overheats then yoke is faulty replace it
Mar 17, 2010 | LG 500LC Monitor
Hi. I need a user manual for my Studiomaster
Hiya Pete, Unfortunately ever since they "restructured" anything prior for service is a huge issue with them and especially manuals. It is difficult to even get on the pay sites. You try request it at www.safemanuals.com but i doubt it. If it's something specific that you are needing, i might be able to help?
Jul 11, 2009 | Audio Players & Recorders
N70 blanking(all display white )
It looks that your N70 has a booting problem. Your phone wasn't booting. Usually the boot IC goes bad and needs t be replaced. You have complicated your problem by changing the glass IC's. This surely wasn't your problem. I'm not sure if you have replaced them correctly though. If you have a digital multimeter than check your phone across the battery terminals. Keep the meter on 'Continuity' which also shows a 'Diode' symbol and check ur phone .Between +ve to grnd, one side, the meter shd show around 370 ohms and reversing the polarity of the meter across the same terminals of the phone the meter shd show a reading similar to a capacitor discharge action towards infinity. Now if these readings do not show, then the phone has a 'shorting' somewhere. I suggest u take your phone to a technician he may be in a position to kick start it back to life.....................
Jan 17, 2008 | Nokia N70 Cellular Phone
N70 network
simple, reset your settings or soft reset but first backup your phone memory when finished get your mmc and resetnit....
Dec 07, 2007 | Nokia N70 Cellular Phone
STK-392-110
They rarely show visible damage,however,the B+ feed resistors
near the IC's can show over-heat or burnt and can change value.
Convergence IC's are changed because of the symtom.......T.
Nov 25, 2007 | Toshiba 43H71 43" Rear Projection...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
