Question about HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop
When press power button of system, the system not work properly but it give vice of ton ton and the indicator power light show light in red color. please tell me what is problem.
  • 32 Answers
Sir
your pc's RAM has become faulty. Whenever any system is not able to load up the RAM it gives exactly the sound which u are telling.i will advice you to the RAM thats the only thing u can do.
thankyou for using fixya
dont forget to rate the solution
Posted on Mar 11, 2009
I have a samsung R620 laptop but the laptop is not booting but the battery and ac adapter are working properly on the system because the battery light shows or indicate tha the battery adapter is okay but...
By pressing power button it is powering on or not if yeas the display light is comming or not? if yes then what is the bios error code please check. If not powering on then remove the battery plug in power adapter and press power button if not on then it is hardware problem go to service centre
Sep 13, 2017 | Samsung R620-64BR Laptop Computer
Although I have loaded my paper properly (i've been using this printer for over a year) it will not feed I get the error message that the paper is not loaded properly. I have tried to reload the paper and...
I will suggest you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see what happens. let me know if additional information is required.
Nov 28, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
Sony DAV-C770 Red Light Flashing but nothing is on!
power supply or power amplifire unit problem.give it to repair proffesional.
nuwan.
Jan 19, 2009 | Sony DAV-C770 System
Error 5800 on Canon Pixma MP170
Solution #1 worked with my MP170 but it could be described more clearly, as follows:-
1. If the power is on, turn it off (press the on/off button).
2. Hold down the stop/reset button (red triangle in red circle).
3. Whilst still holding down the stop/reset button, hold down the on/off button.
4. Whilst still holding down the on/off button, release the stop/reset button.
5. Now press the stop/reset button twice, quickly.
6. Next release the on/off button.
7. Wait untill the LCD display shows “Canon idle” (this may take a few minutes).
8. Now push the stop/reset button 4 times in succession, quickly.
9. Press the on/off button twice, quickly.
10. Now press the on/off button to switch the power off.
11. Finally, press the on/off button to switch the power back on.
This sets the ink pad counter to zero, even though the pad still contains ink.
Remove ink from the pad, as follows:-
Open the lid of the printer to reveal the cartridge track and ink pad.
Winkle out the ink pad, using a pin or a small screwdriver or tweezers.
Wash the ink pad in clean water, squashing the pad to remove the ink.
Dry the clean pad by squashing it between sheets of kitchen paper.
Replace the pad, taking care to fit it between the alignment notches.
Amen!
Jan 09, 2009 | Office Equipment & Supplies
Reset Button
your testing the no fault short or motor overload feature. the red light indicates you have power. no light no power.
Apr 02, 2008 | Karcher 2500 PSI Pressure Washer
Dell optiplex gx260
Reference the Power LED States
Dell OptiPlex and Dimension computers and Dell Precision workstations have incorporated the use of the multi-state power button LED as a hardware status indicator. The power button LED illuminates in two different colors and can also blink, which allows for indication of five different system operation states. (Table 1)
LED State
System State
Steady Yellow The power supply is functioning, but the system is not processing data. This may indicate an issue with the system board or CPU. Blinking Yellow The power supply is receiving power from the source but is unable to properly distribute it to the components. This may indicate a power supply problem. Steady Green This generally indicates that the system is functioning normally. However, if problems are detected with installed components, the system may initiate a beep code. Blinking Green The system is in a Standby ACPI state. Off The system power is off.
Feb 24, 2008 | Dell OptiPlex GX260 PC Desktop
900Proview 19in.Flat panel LCD Monitor
Hi, If no indicator lights, no reaction when push the power on button, then chances are that you have a power supply problem. If your particular brand/model has a built-in power supply then it has to be opened up and diagnose. Normally most units would show a light indicator by simply plugging it into an outlet. That light changes color or another one lites up when the power on button is pressed. Absence of the first light indicator means that the system is not getting any power at all. You would be better off seeking the services of a qualified professional. But then again, it just might be the power cord which is of course relatively easy to replace. Try using your computers cord first for the monitor if it fits and matches. Hopes this work out for you and give you an idea or two. Pls post again how things turn up. Good luck and kind regards.
Aug 03, 2007 | Proview PL 566s 15" Flat Panel LCD Monitor
HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
