Question about Samsung RF26XAERS
How to unfreeze water tank on Samsung RF26xaers
Refrigerator would have water and ice under crisper drawers. We repeatedly unthawed. Now fridge and freezer wont cool. What could it be?
When you thaw it out it still isn't thawing the Air vent that brings cold air up to the Frig. This will usually freeze up the circulator fan.
Common problem with these side by sides.
Mar 02, 2016 | Samsung RF26XAERS 26 Cu. ft. French Door...
Ice maker stopped making ice after filter change
these seem to air lock when filters are changed try loosening the fitting on the filter( out put side ) just enough to let water start flowing then tighten it back up
May 05, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
How can I tell if my water line tank heating element is broken? Should it get warm to the touch?
no it should not. If fridge fan is working water should not freeze.
check for fan motor operation.
Apr 03, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
Water dispenser drips
The water inlet valve needs replacing. It's located in the rear of the refrigerator and can be accessed by removing the cover (either cardboard or metal). The water line is attached to the water inlet valve. You can order the part online or purchase one from a local dealer.
Mar 08, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
All I get on my Samsung screen is the letters 88 88. Nothing else and I cannot set the temp.
Richard, I have the same problem with mine, model RF26XAERS. Have you found a fix yet?
Oct 20, 2014 | Samsung Refrigerators
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
Frige part bottom shelves get frozen water and ice dosent work
This is a known problem. Samsung knows about this and if you call them they may come out and fix it for free. Otherwise, the water tanks are frozen along with everything else. Unplug the machine. Take the vegetable/salad draws out and you will see the water tank. You need to unscrew this and lay it against the inside of the fridge. Now remove the lower half inside back panel by the six screws, two will be behind the vent like plastic covers. Unplug the two juction boxes and remove the back cover. You will find that everthing is frozen, take a hairdryer to the lot of it including the drain away hole at the bottom of the lower half. re asemble and all should be ok......until the next time. Ensure you completely unfreeze the drain away or you will get water leaks.
Jan 26, 2014 | Samsung Refrigerators
Samsung RF26XAERS Logo
98 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
