Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
SONY WEGA KV-36HS420 will not come on
I'm getting a 6 blink diagnostic code when the unit is on and 7 blinks when the unit is off. You can hear the unit power up when turned on but then shuts off after a few seconds. If I unplug the television for about 6-8 hours without reattempting to plug it back in to test it, it will turn on and work normally when plugged in again.
  • Sony Master
  • 13,433 Answers
Hi I have the details on those two error codes here
# Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
# Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Posted on Mar 11, 2009
Kv-36hs420 sony wega 2004 red light blinks 6 times and won't turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 14, 2014 | Televison & Video
What do sony wega blink codes mean?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Aug 11, 2014 | Sony FD Trinitron WEGA KV-36HS420 36" TV
How to locate 2SK2842 on kv-36hs420
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sony trinitron model kv 36hs420. t.v. will turn on for a few seconds, then turns off on it's own. (you can hear sound but turns off before picture comes up) Red light on front blinks. This happens if...
I have fixed this problem, on one of these.
It is a voltage regulator, and it probably died after a power outtage or surge,
am I right?
Get it to a fixer guy, Its a very affordable repair.
are you in VB? I'll do it!
Aug 30, 2011 | Sony FD Trinitron WEGA KV-36HS420 36" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
We have 7 blinks on my KV-36HS420 Sony Wega Triniton. It will come on with only 5 seconds of audio and then shuts itself off with 7 blinks. What part does it sound like needs to be replaces
The power supply in all likelihood. Not something you can do. Any tv repair can take care of it but will likely charge $25-30 for an estimate. They have to spend a bit of their time to check it out. The cost of the estimate will go towards any repairs.
Aug 11, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony wega tv blinks seven times and does not come on
seven blinks means high voltage shutdown it gone into safety mode you need to check power supply regulation and horizontal circuits
shaun
Jan 16, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Oct 01, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
