Has a Kohler motor and battery goes dead after running a day. Replaced Battery, and Stator replaced last summer.
SOURCE: 15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
SOURCE: My Husqvarna LT1538D riding mower only charges the
On almost any engine you pull the flywheel and you will see the charging coil. Once out it can be tested by yourself or any competent electrician. Good luck. donnyb60
SOURCE: montgomery ward lawn tractor kohler
If your engine is an OHV engine you need to adjust intake and exhaust valves. Go to smalleng.com watch video clip. or go to U tube lots of tutorials there. Good luck...
SOURCE: my cub cadet will not charge the stator is putting
Check to see if you have 12 to 14 volts at the battery with the motor running.
If not, you probably have a bad Voltage Regulator.
