Question about Black & Decker Garden
Model number hsko12hd
Plug
Need spark plug number for a b&s tiller 206cc motor mod 500282
Briggs & Stratton does not have a listing for model number 500282. Could you please check to see if you can find another model number somewhere on the motor?
Nov 14, 2016 | Garden
What spark plug does a poulan bvm200vs blower uses
Go to manualslib.com put in your model number and you can pull up a manual on your model and in spec. sheet it will show you the plug number. Hope this helps.
Jun 11, 2014 | Poulan Pro Gas BlowerVacuum ()
I bought a used avanti freezer model # cf2010 and it didnt come with a drain plug. Where can I get one?
most appliance stores can order you one , if you have your model # and serial number,, or you can do a search on www.amazon.com
May 12, 2014 | Avanti Freezers
Toro snowblower troubleshooting
FOLLOW this steps and fix it. Merry Christmas
Spark Plug
Every chainsaw relies on a spark plug to ignite the air-fuel mixture for proper combustion. Over time the electrode on the spark plug will burn away and the engine does not start. If the engine does not start, remove and inspect the spark plug. If there is any doubt that the plug is working properly replace it.
Enter your model number to see parts for your chainsaw.
Carburetor
If the chainsaw won't start, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the chainsaw for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn making it hard to start the engine. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
On - Off Switch
Chainsaws are equipped with an on/off switch. If the chainsaw does not start, this switch might be defective. Check the switch for continuity. In the on position the switch should have continuity.
Safety Switch
If the chainsaw does no start, the safety switch - or throttle control switch - might be defective. If the switch isn't engaging with the throttle it won't provide enough fuel to the engine and the engine does not start.
Ignition Coil
If the chainsaw engine does not start the spark plug may not be getting voltage. Power to the spark plug is provided by the ignition coil. The ignition coil is mounted next to the flywheel. As the flywheel spins an electrical current is induced by the ignition coil. If the ignition coil is defective it will need to be replaced, it is not serviceable.
Rewind Spring
The recoil starter assembly has a rewind spring which spins the pulley backward to rewind the starter rope. If the rewind assembly is broken the rope will not rewind and the engine does not start.
Recoil Starter
If pulling the recoil starter assembly handle doesn't engage with the engine and the engine does not start. Repair or replace the recoil starter assembly.
Recoil Starter Pulley
The recoil starter pulley winds up the starter rope when not in use. If the recoil starter pulley is broken or stuck it may not rewind the rope and the engine does not start.
Dec 19, 2013 | Toro Garden
Refridg nutZ
f54adfa5-965b-4b11-879a-627973789383.jpgKenmore has a model number like this example=> 321.12345678 Can you look around the fresh food section door frame for your model number? I need the model number so I know what to look for in the components that may cause this. A defective or bad connection at the pin plug leaving the door and
going to the control board is one possibility. A damp or corroded connection, loose pin plug on any circuit boards and even a defective thermistor. Let me know if possible, Thanks Sea Breeze
Jun 02, 2013 | Refrigerators
Missing power Plu g were can i purchase
Let's start with;
1) What kind of power plug? You're in Desktop PC's, (He states politely)
Adapter power plug for going from one country to the next?
2) Are you referring to an AC adapter (Charger), for a laptop?
3) What is the computer manufacturer name, and model number?
Model number can be found on the back of a Desktop PC, next to the Windows product key; or up on the side of the computer tower.
Model number for a laptop is on the Bottom.
Post back in a Comment.
Regards,
joecoolvette
Mar 03, 2013 | Computers & Internet
Have an MTD Chipper-Shredder Model 462B 5 H.P. lost the spark plug. What size do I need?
That model number is not helpful. I need the full model number on the manufacturer's label. Or even better, the full model number on the engine (separate label from the one for the whole machine). Need the make of the engine if you can find it. I have a Craftsman (that I think may have been made by MTD) that has a Tecumseh engine. But it was not stated on the machine, I had to find the brand by using the model number for the whole machine and looking it up from there to find the maker. If it is a Tecumseh engine, the label will be low and left on the engine shroud as you are looking at the shroud, spark plug points up.
If you can give me the label plate data, for both labels, then I will be able to tell you what the spark plug should be.
Sep 08, 2011 | Mtd Garden
I need the part # for the icemaker ordered
Now here is the confusing part. If your model number is a GE PDS22LBN the Ice Maker would be part number WR30X10039 for the model number posted above your post. If you have sears model number for the refrigerator it will be like 312.235698 for example. Confirm the model number of the refrigerator and I can tell you the correct Ice Maker part number. Thanks Sea Breeze
Feb 18, 2010 | GE PDS22LBN Bottom Freezer French Door...
NOT GETTING FIRE TO THE SPARK PLUGS
Hello Momtexas1:
>>Remove the Spark Plugs and Wrap the Threaded Section of the Plug with Wire, then Attach the Other End of the Wire to the Engine Block.
>>**First Make Sure the Plastic End that Snaps to the Plug is Allowing Current to the Plug. Use a Test Light or Multimeter and Check for Fire Behind this Connector (through the Large Rubber like Coil Lead to Plug) for Fire to the Plug whenever there is No Fire to the Plug.**
>>Once you are Sure the Coil Lead and Ends to the Plug are Not the Reason for No Fire to the Plug, then with the Plug Still Wired to the Engine and the Coil Lead Attached to the Plug; Remove the Coil Shut Off Wire at the Shut Off Switch.
>>Check for Fire. If No Fire, then Remove the Cut Off Wire from the Coil (removal of the blower housing required) and Check for Fire.
>>If the Spark Plugs are Firing with the Plugs Out and Properly Grounded to the Engine, then Replace the Plugs and Start the Engine.
>>Using an Insulated Plug Wire Puller, Pull the Plug Wire from 1 Cylinder. If the Engine Continuse to Run, then Replace the Plug Wire and Disconnect the Other Plug Wire. If the Engine Quits, then Replace the Other Cylinders Coil.
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>Thanks.
Respectfully
John
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Presto Model 0692001
Same her but I found this info,
Presto multi cooker magnetic cord 09984
Replacement magnetic cord fits Presto Kitchen Kettle multi cookers from model numbers 0600001, 0600002, 0600003, 0600004, 0600007, 0600009, 0600010, 0600101, 0600110, 0600203, 0600305, 0600306, 0600308. Original part number 09984.look on the bottom of the fryer not on the plug to find these numbers.
Nov 13, 2007 | GE 168997 Deep Fryer
Garden Logo
29 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
