Question about LG 50PX5D 50 in. Plasma HDTV
I have a 2 to 3 year old lg 50px5d-ub and all of sudden the hdmi inputs will not work - shows no signal. component works great still but neither hdmi 1 or hdmi 2 works. tried two different cables and both inputs???????
  • Anonymous Mar 29, 2014
    The HDMI input has never worked on my TLX-04011C 40" but I am trying to get rid of cable and really need this to work. I have tried 3 different hdmi cords of varying prices (up to $40) and none of them work. Tried unplugging everything and then plugging in my Roku to no avail. Is there anything I can do?
  • 36 Answers
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you save $300 least!
Posted on Mar 15, 2009
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
Hdmi ports om our lg tv are not working
yes you have to replace the mainboard just buy the part yourself and install it there's not much to it buy the part @ www.shopjimmy.com
Mar 02, 2013 | LG 47LW6500 47 3D LCD TV
I have a Sony Wega DLP with no sound through HDMI all of a sudden. Can't give exact model at the moment but it is a projection TV definitely 5years old at least. It has only 1 HDMI input and I've been...
The first step, and you hinted at it already, is to check cables and connectors. Especially with any electronics that old, connectors go bad if the wiring is moved, wiggled over time.
What you could try, since your WEGA is an older unit, is to connect your peripheral devices through the Component Inputs to your TV- at least one unit and see if the problem is resolved. Then you know for sure its either a cable or a connector.
Next step- try another HDMI cable and see if the sound comes back. If not, then its either the connector or the internal TV amplifier.
To troubleshoot the question on the amplifier, take a "Line Out" off your TV and run it to a stereo to see if audio is coming through. This is a lower level signal and doesn't rely on the higher power transistors required for a TV amplifier. If the Line Out audio works, then you know the TV amp needs repair.
Keep us posted!
Chad
Jun 25, 2017 | Televison & Video
Only av input is working LG 42LC7D TV
I may put money that some one did stole your internal cable from the power supply to the main board !
Don't be surprised they did it to me at LG company .
Jul 26, 2010 | LG 42LC7D-UB Television
LG 37LC2D HDMI no signal (picture or sound) + crackling on audio
i have the same problem. i think they just get old, i solved the audio problem by taking the cove off the back and disconnecting the speakers, i now just use PC speakers, works grand. i haven't solved the HDMI problem yet..
Apr 29, 2010 | LG 37LC2D Television
My LG 42pg3000 stopped displaying hdmi inputs.
I have a similar issue. HDM1 does the same thing, did you ever find a solution?
JP
Apr 05, 2009 | LG Televison & Video
Input Problem
Mine was the same, except i also could not access HD Components.
Unfortunately i had to get some one in, as the circuit board at the back of the tv was burnt out.You might have to get a technician in to service and replace the burnt circuit board.
Jan 16, 2009 | LG 50PX5D 50 in. Plasma HDTV
Only HDMI2 input works
try attaching all the sources you have to hookup, have the power on , on each unit and then go into tv menu and run auto program. if this is no help your tv may just need a firmware/software upgrade, I don't know if they give the download to the consumer or not but if the auto programming doesn't work call LG @ 800-243-0000 tell them your problem, 4 days old really don't recomend having extensive service work but it is under factyory warr. so you have the option but if they think it's the firmware upgrade and you have a usb flash drive they may send you an email with the software.
Feb 29, 2008 | LG 50PX4DR 50 in. Plasma TV
No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Dec 04, 2007 | Hitachi PJTX100 Multimedia Projector
LG 50PX5D 50 in. Plasma HDTV Logo
205 people viewed this question
Computer Repairing
Computer Repairing
