Question about GE Monogram ZIR36NMRH Refrigerator
Refrigerator zir36n drain blocked
Tryed vacuum and tryed vacuum blower and tryed hot water still blocked . can not see hose below refrig also pan dry can not move refrigerator built in
Sea Breeze
  • 4654 Answers
SOURCE: Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
Posted on May 19, 2009
MNTECH
  • 1543 Answers
SOURCE: water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Posted on Jun 07, 2009
aasc
  • 1606 Answers
SOURCE: GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
Posted on Aug 02, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Posted on Aug 26, 2009
terrencio
  • 20 Answers
SOURCE: the water is overflowing from the freezer onto refrig shelf
Yes, let the unit thaw out, and replace that thin wire. it's called a drain heater, it simply keeps the water from freezing before it gets out the drain.
Posted on Sep 26, 2009
How to clear drain line on refrigerator
i have had luck cleaning refrige drain lines in 2 ways,make sure theres no ice in the drain line just below the freezer drain pan,then try a piece of plastic hose available from any hardware or home stores and feed it down the drain under the drain pan and blow into the hose to pressurize the line it may dislodge the blockage,if not,try a piece of wire and rat the line out till water drains
Feb 20, 2012 | Kenmore Top Freezer Refrigerator
Water is always laying on shelves and under vegetable drawers, drain pan is dry, has ice maker, but we do not have it hooked up. This is located in our basement in a pantry.
That water is coming from the defrost cycle ..their is a drain that usually drains that water into a pan in the bottom of the ref.but that drain is blocked so the water is dripping inside from the vents in the ceiling of the refrig.
This tip i wrote will help ya to clear that blocked drain.
http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 25, 2011 | Refrigerators
TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS ONTO TOP SHELF AND UNDER BOTTOM DRAWER
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Jul 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is dripping into the bottom of my fridge. I have cleaned and vacumned the coils. How do I access the drain to see if it is frozen?
Remove the ice maker and back panel in freezer.1/4 inch nut driver to remove screws. there are 3 screws for the ice maker 2 on the back wall and 2 on the bottom panel. Use a hair dryer to melt ice block.All water will flow down into drip pan under fridge. May overflow use a turkey baster to remove water from pan. Pour hot water onto drain until the water flows freely into the pan.
Jun 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is dripping from the freezer compartment into the fridge compartment.
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home. Or this sounds like you have a blockage in the drain tube, remove panel back of freezer...you may see ice build-up, melt ice with hair dryer, you will see a pan below evaporator, melt ice in pan, dry water up in pan with towel, now you should see drain hole in pan that leads to drain tube, pour some hot water in pan, wait a couple minutes, wipe up water and repeat this step 2-3 times, once you have done this use a wet and dry vacuum cleaner to vacuum out the gunk or blockage in the drain line. Now it is cleaned out! Put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. Good luck! PS Please don't forget to rate my solution Thanks! Sea Breeze One moment I will send you to a ink and scroll down the page and read and watch movie Click Here=> Sea Breeze Tip's
Mar 13, 2010 | Whirlpool Refrigerators
Bottom of freezer in the side by side builds up with ice, then water leaks on to the floor
We have a defrosst drain problem we will need to work on, WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
Feb 06, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Kenmore Cold spot refrigerator model 106 70182001 leaking inside in the back of the refrigerator. Having to keep bowls in the back of the top shelf. How can I fix this?
Your defrost drain in the frezer is cloged. Every day when your refrig sellf defrosts the water should drain into a hole that leads to a tube wich drains the water to a pan under the refrig. You need to turn offrefrig and remove frezer floor and rear wall and clean out hole and tube with hot water.
Dec 12, 2009 | Cars & Trucks
Frigidair icebox leaks water...condensation pan is dry Model # FP1-19THL-1
Remove the food and ice maker (if equipped ) from the freezer , and remove the rear inside freezer panel . Below the coils , there is a drain pan which is probably iced over . Start in the middle with a hair dryer , and defrost until you see the drain hole . Use hot water to help defrost the hole . Once defrosted , insert a small hose , to blow any unseen debris , thru the drain line , and into the drain pan .
To permanently "fix" this problem , after defrosting the drain hole , insert an aluminum solid wire ( no insulation ) , or a copper ground wire , into the hole as far as possible , without force , and wrap the black rod above the hole (defrost heater) , about 1-2 turns with the other end of the wire .
When the refrig goes into defrost , the heat will transfer to this wire , keeping the defrost drain from being frozen up again .
Oct 06, 2009 | Refrigerators
Water laeks into the refrigerator part of refrig from the freezer above. pan at bottom of refrig is dry. I think drain is blocked. how do i solve this for a whirpool model et18nkxjw00
you are probably right. the drain is located behind the back wall of the freezer section, under the evaporator coil. simplest fix is to remove the rear panel and unplug the fridge,prop the doors open and let it melt on its own, a hair dryer or hot water may speed up the process.
Jun 11, 2009 | Whirlpool GD2SHGX Refrigerator
GE Monogram ZIR36NMRH Refrigerator Logo
43 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
