Question about Casablanca Fan Dryers
Casablanca Ceiling Fan Receiver 7801750 ( - Casablanca Fan Dryers
1beertap
  • 32 Answers
SOURCE: Casablanca Fan W21 Ceiling Fan
Hook the fan's wires up as follows: black = black (hot) white = white (neutral) green = green or bare copper wire (ground) red = not used, so cap off (hot) The red wire is for a light kit. You may have a second switch on the wall to control this. Usually, the ceiling fan will have a red with a green tracer wire that goes with the red wire. If not just cap the red wire off and don't use it.
Posted on Jun 10, 2007
  • 3 Answers
SOURCE: Fan turned on by phantom signal
Have had similar problem for years when main power supply is interrupted for even a few minutes (lightening storm, brief outage of some sort). When the power supply returns, the fan starts up at the highest speed - not great when you aren't at home. (Mine is in an older kitchen with old time gas pilot lights in the range.) I replaced the wallswitch control - but I still turn off the main power switch when I know I won't be at home
Posted on Jun 28, 2008
  • 70 Answers
SOURCE: Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
Posted on Jul 25, 2008
MN_Jack76
  • 45 Answers
SOURCE: our casablanca ceiling fan has
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Posted on Feb 06, 2009
SOURCE: Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Posted on Aug 05, 2010
I need to change the receiver and transmitter of Casablanca Scandia Ceiling Fan 88u33m. How to open the fan / dome and is there a newer replacement for the receiver and transmitter.
remove fan from ceiling [ safer way to work on it ] and receiver is in wire cover and any place that sells fan usually have a remote system
Jul 14, 2017 | Dryers
Need a internal wiring diagram for a Casablanca Fan P4M55H
I don't think you can do that if it came with a built-in receiver.
Jul 07, 2014 | Casablanca Fan P4M55H Cosmopolitan...
Fan working but light won't turn off from remote
Call Casablanca @ 1-800-715-0393. It could be a bad light kit ( which can be replaced) or bad receiver.
Jun 01, 2014 | Casablanca Fan 3245T Ceiling
Only works in third
Probably needs a new receiver. Call Casablanca @ 1-800-715-0393
Dec 14, 2013 | Casablanca Fan 3029818293 Stealth Ceiling...
I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
I have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
Receiver 85112-04 need a replacement for hunter fan remote receiver which is housed in the based of the fan in ceiling.
I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from
Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below:
http://www.casablancafanco.com/Parts-Manuals/Part-Manual-Detail?ModelNumber=54019
Apr 11, 2010 | Hunter Ceiling Fan Remote Receiver...
Fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Aug 07, 2008 | Casablanca Fan Televison & Video
Our casablanca ceiling fan has power going to the fan and the remote works but the fan does not nor does the light
Jun 25, 2008 | Casablanca Fan 3245T Ceiling
Dryers Logo
236 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
