Question about Panasonic Digital Transmitter Card Sh-fx65t
Rear speakers won't play - Panasonic Digital Transmitter Card Sh-fx65t
Subwoofer wont play!!
first clean your board.ok.....same problem......?remove chargin connector
Jun 14, 2013 | Audio Players & Recorders
Rpm won't go over 4000 and will not do over 30 mph
2002 GMC Envoy Car Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jul 23, 2012 | 2001 Dodge Stratus
ViewSonic Speakers won't work
Sound issues and answersA VERY SHORT LIST OF ISSUES AND ANSWERS-
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD. (IF SOUND WORKS VIAREAR INPUTS IT IS A SETTING IN THE TV OR THE BOX.
Apr 07, 2012 | ViewSonic N4285p 42 in. LCD TV
How to turn off rear speaker?
ensure you have the latest drivers installed. if the package won't allow the rears to be disabled. try simply changing the speaker setup to "stereo" speakers.
Dec 24, 2011 | Cars & Trucks
My speaker won't work even i have set in...i can't hear anything from mp3 and even real media also can't be played.
Reinstall the sound driver and download multimedia player in the net, it's free!
Hope that helps!
Dec 20, 2011 | Computers & Internet
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Panasonic Digital Transmitter Card Sh-fx65t Logo
27 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
