Question about LG Studioworks 563N 15" CRT Monitor
Pictures on screen gets elongated frequently.
Since last 3 weeks all pictures gradually stretch vertically upto the extent that only few lines r visibles giving unclear image 4 few seconds then comes to the normal form of its on or hitting on it slightly. This happen very frequently at the starting of computer but reduces wen internet is on. It happens even at any small vibrations on the table where it is kept.
this problem starts suddenly on a day. I dint find any loose connection also.
Where can b the problem ? Is it a serious one?
PLZ help me n guide me as soon as possible.
which part is asked 4 Model name i dont know.
  • Anonymous Mar 25, 2009
    my monitor screen has shrunk and appearing in 3 vertical...
  • 700 Answers
First check its signal cable for loose connection reseat if ever. If it does not help.We will come down to its internal circuitry.Check its vertical IC for loose connection or failing IC, its supply filter capacitor and other capacitor connected to it.
If you are not even familiar with electronic servicing I suggest you do not work inside its circuitry.
Posted on Apr 14, 2009
Why does it have vertical lines and no picture?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 16, 2016 | Vizio Televison & Video
I have a Sony Bravia KDL 52W3000 LCD TV that frequently displays vertical lines when it is turned on.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 29, 2015 | Sony Televison & Video
Toshiba 32" Full Picture w/ vertical White Lines?
Sep 03, 2014 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
How to build height without medicines suggest only exercise
1. VERTICAL HANGING:
This is a simple but an extremely effective stretching exercise which you can do at your home. All you need to have is a solid bar strong enough to hold an individual, fixed at least 7 feet above the ground such that the distance between your feet and the floor is atleast 4-6 inches. Hold your arms neither closer nor wider and start hanging. Hold as long as you can, and as you begin to tire, slowly swing back and forth and try to touch the ground with your feet. This will flex your spine and elongate it, so that you can add few inches to your height
Make sure that you flex your spine while stretching, and not merely twisting your wrists
Perform the Workout 3 times a week for optimal results
2. COBRA STRETCH:
This is basically a Yoga exercise intended to stretch your spine and make it supple and flexible, so that the cartilage between your vertebrae grows thereby increasing your vertical height
Lie on the floor face down with palms on the floor under your shoulders. Begin to arch your spine up leading with your chin. Arch as far back as possible. Do 3-4 repetitions with each repetition lasting between 5-30 seconds
3. PILATES ROLL OVER:
This is an excellent workout to stretch your spine and lengthen your upper body. Apart from your spine, it also stretches and lenghthens the vertebrae of your neck.
Lie on your back with your arms along your sides, palms down. With your legs together, extend them straight up toward the ceiling and bend them backwards so that they touch the floor. It may not be possible to touch the floor at first, but you can do this by practice. The more your stretch, the more your spine lenghthens
4. FORWARD SPINE STRETCH:
Sit up tall on a mat. Your legs are extended about shoulder width apart, and your feet are flexed. Reach the top of your head but let your shoulders stay relaxed. Inhale and extend your arms out in front of you and slowly bend forward and try to touch the tips of your toes. If you are able to touch your toetips, stretch even forward so that your spine is flexed to the maximum extent.
Do 3-4 repetitions and hold each stretch for 10-15 seconds
5. ANKLE WEIGHTS: This exercise is solely intended to increase the length of your lower body, by stretching the cartilate between your knees. Prolonged stretching will elongate the cartilage and increase its mass, which in turn will increase the length your lower body
Sit on a high chair and use a Ankle weight fastener to add weights to your ankle. Start with small weights initially and gradually increase as you go on. Allow your legs to stretch down with the pressure of the weights. Once completed, remove the weights and relax your legs by kicking your legs gently for 5-10 times, and then vigorously for 5-10 times. This will flex your knee cartilate to enable it to grow in length
Apr 13, 2012 | Health & Beauty
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
Top of creeen rolls over and back down from the top about 3"
There is a capacitor in the vertical circuit that has significantly changed value causing this. If you are familiar with these units, look for a capacitor with the value of around 100ufd that is part of the vertical circuit and change it. That should resolve it. If you bring this to a shop, expect a parts cost up to $10.
Dan
Mar 17, 2009 | JVC AV-27920 27" TV
52 inch Hitachi rear projection HDTV. No picture. Just vertical colored lines.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 15, 2017 | Mitsubishi WD-52525 52" Rear Projection...
Elongated picture on Sylvania 27" Model # SRT2232S
there is a vertical adjustment on the picture tube it's the yoke as it's called but you can adjust it so much..but it does sound like the tube is on it's way out
Aug 28, 2008 | Sylvania 6427TE 27" TV
Vertical stretchon pictures
This is from what you describe - more the computer dispkay than a camera proble.
How do other images look[not the camera] on the screen?
or the deck top. -Check out this first them come back to the camera images.
Nov 15, 2007 | Canon PowerShot S3 IS Digital Camera
LG Studioworks 563N 15" CRT Monitor Logo
123 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
