Question about Crown XTi 4000 Amplifier
XTi 4000 Amplifier short 1
When the amp powers up it reads " short 1 "
  • 4234 Answers
SOURCE: i need the schematic for the crown amplifier
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Dan
Posted on Jun 29, 2009
Ganx
  • 113 Answers
SOURCE: Crown XTi 4000 brand new digital amp how can i
Hiya, to unlock press PREV and NEXT until it says unlocked.
The short 1 sounds a little serious though. Have you tried taking off the speakers?? If still there then suggest contacting crown. They have a pretty good no nonsense 3 year warranty
Best of luck
Posted on Jul 14, 2009
Grubhead
  • 5151 Answers
SOURCE: XTi 2000 2-Channel Amplifier: when power is switch on amp don't play i have to t...
A loose wire or bad solder connection.
Posted on May 16, 2010
  • 140 Answers
SOURCE: Where are the fuse located
The fuses are on the inside
Posted on Dec 14, 2010
  • 1212 Answers
SOURCE: my amp was blinking while it was working then it went off.Now it doesn't power up..Crown Xti 4000
Power supply likely failed. Electrolytics are the primary culprit.
It should have a switchmode power supply, so it is lmost likely the 5 volt section failed.
Posted on Sep 27, 2012
My amp was blinking while it was working then it went off.Now it doesn't power up..Crown Xti 4000
Sep 17, 2012 | Crown XTi 4000 Amplifier
I got a cadence q 4000 and i what a the bass to sound louder
the Q4000 only funs 400 max and thats at 4ohms bridged 2x200 if you need high powered amps i would look at soundstream or MTX and you would need atleast 1 secondary battery cause to max a amp out you need to have constant 14.4 volts going to power the amp.
Jul 31, 2010 | Cadence Q200 2 CHANNEL POWER AMPLIFIER...
Amp would not turn on after power outages (twice in 30 min), I had it plugged in to the power conditioner, it wasn't hooked to the wall outlet.....please advice
Switch off the amplifier for some time and allow it to reset. disconnect the speakers and reduce the volume level before you put it on. If the power does not come on you will need to probe inside. Get help if you are not familiar but check on the power lines coming in for failure of fuse, the secondary power supply section transformer or the smps power. Hope it would not go further to this but check this out.Check for shorting inthe outputs, if so disconnect and test. Good day
Jul 30, 2010 | Crown XTi 4000 Amplifier
Fan don't work when power is turn on crown xti 4000
the fans on these amps are heat sensitive, only when the amp heats up, then they come on
Mar 27, 2010 | Crown XTi 4000 Amplifier
Dsp off
Try here:
http://www.crownaudio.com/express.htm
Mar 22, 2010 | Crown XTi 4000 Amplifier
Crown XTi 4000 brand new digital amp how can i unlock it? i dont know but the screen display short 1
Best of luck
Jul 13, 2009 | Crown XTi 4000 Amplifier
Crown XTi 4000 Amplifier Logo
62 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
