Question about Vizio VBR220 Blu-Ray Player
Can't watch hulu plus on vizio blu ray player VBR 120
  • 16 Answers
SOURCE: our vizio blu ray player
Please inspect the HDMI connector on the back of the Blu-Ray player to make sure none of the pins (top and bottom) are not push back inside the connector. If there are return the unit for a another unit.
Posted on Feb 24, 2011
muntejaya
  • 10421 Answers
SOURCE: what is my code to hack the multi-region on my
Please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__hytg34
Posted on Feb 27, 2011
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
t407803
  • 84 Answers
SOURCE: A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Posted on Apr 11, 2011
Testimonial: "This site was extremely helpful. Received resonse very quickly."
SOURCE: When I try to update
unlock server error 11000404 on a vizio blu ray vr210
Posted on May 14, 2011
How to get youtube on my vizio vbr 334 blueray
Hi Anonymous, Youtube is on the internet and as far as I know you can't get the internet on a DVD player.....
Mar 27, 2016 | Vizio Televison & Video
My Vizio Vbr 220 wont play Videos from my usb
MP4 or AVI files will definitely work but make sure your USB memory is formatted in FAT32.
Aug 14, 2015 | Vizio VBR220 Blu-Ray Player
I have a vizio vbr 2011 wireless blu ray player. im unable to connect it to my arris dg860p2 routor. please help
i presume you mean a VBR210.
Both the player and router use 802.11N at 2.4GHz so they are compatible.
Check the security on the router that it does not require MAC addresses.
Check the firewall, DHCP and parental controls on the router
Try a hard cable to see if that works.
Most smart units will not setup WiFi if you have a network cable plugged in.
Try both the press button and manual PIN methods to connect the player
See the manual pages 20-22
Good luck
May 28, 2014 | Vizio VBR210 Blu-Ray Player
Vizio vbr 333 firmware update
http://cdn.vizio.com/documents/downloads/accessories/VBR120/VBRFW_Instructions.pdf
Dec 23, 2012 | Vizio 3d Blu-ray Player With Wireless...
Vizio vbr210 error 11000404 How do I update firmware to watch newer blu ray movies?
I had the same problem -- we even returned the disc and got a new one. Go to the Vizio site and download the firmware for your player. Put it on a USB stick and plug it into the player. Follow the onscreen instructions (basically just press OK). The entire process takes less than 5 minutes from download to finish.
The Hunger Games works perfectly now.
Aug 21, 2012 | Vizio VBR210 Blu-Ray Player
Hulu plus app
Refer its user manual for details.
May 31, 2012 | Vizio VBR220 Blu-Ray Player
How to register my new vizio Blu-Ray Player
Usually can be done by mail or on the site as indicated with the paperwork that came with the unit.
Apr 29, 2012 | Televison & Video
My Vizio VBR-100 Blu-Ray Turns on once connected to the wall outlet, but does nothing else like showing any thing on the tv input. Why?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 21, 2017 | Vizio VBR100 Blu-ray/HD DVD Player
Need a user manual download for vizio blu-ray player, model-vbr 120.cannot find in listing. the quick stard manual says it can be downloaded.
Here ya go:
http://70.168.148.201/documents/downloads/accessories/VBR120/705VBR120%20User%20Manual%20Rev1.pdf
http://www.vizio.com/home-theater-1/vbr120.html
Mar 14, 2011 | Televison & Video
Vizio VBR220 Blu-Ray Player Logo
115 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
