Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
Sir, I have 750 unlimited scheme broadband connection from BSNL.
I connected the broadband modem to 8 port D-Link switch and distributed the connection to three pcs. with the gateway of by giving SYS Ip as, and
now i would like to connect two more pcs through switch but I can not make this connection. Whenever I connect the 4th Pc to switch it will connect to switch but i can't surf the internet with that pc. the IP Address of 4th pc shows 169.254.....192.
so please help me how can connect two more pcs to internet with 8 port d-link switch
gc shekar
  • lord_loki
    lord_loki May 11, 2010
    Which switch do you have? You should set up the 4th and 5th pc the same way as the first 3
  • 3 Answers
First thanking to using d link switch
Tell me Your dns
and using pppoe ya proxy
Posted on Mar 15, 2009
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
I have a router and switch d-line brand,how to bsnl broadband connection give to multi user
Dec 22, 2012 | Computers & Internet
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot establish broadband connection from cd
Try downloading drivers for the device. Google is youre friend :]
May 27, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Can connect ps2208b to my desktop pc
cable length is 100 meters long. how can i connect?
Apr 13, 2009 | SMC Compex PS2208B 8 Port 10/100 Fast...
Adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
Apr 11, 2009 | Computers & Internet
About connectivity problem
Sir please use a router where you can connect all your switch's. However router needs to be configured properly based from your internet type and settings
Nov 04, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of and a subnet mask of
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
Jun 28, 2008 | Intel Motherboard
Siemens ADSL Modem(model- C2110)
siemens c 2110 modem 3 lights flasing continously what to do
Mar 08, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
631 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
