Question about HP Compaq Presario CQ57-229WM Notebook PC
Compaq Presario CQ57, hard drive failure, code 303, 301, 305
    Top Expert:
  • HP Master
  • 26,697 Answers
Replace the hdd.
Posted on Oct 19, 2015
mailtoravi
  • 186 Answers
SOURCE: compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Posted on Oct 18, 2008
PABLOCSA
  • 1124 Answers
SOURCE: hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Posted on Nov 05, 2008
Geekman
  • 32281 Answers
SOURCE: I have a Compaq Presario V3309TU Notebook PC. I
The problem is that XP installation CD does not have a SATA driver, unless you have a Compaq SATA drive on a disk etc and can install it when XP asks for a hard drive driver, then XP cannot detect the hard disk and therefore won't install XP.
The Fix.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Posted on Mar 14, 2010
Testimonial: "Thanks! Your advice helped a lot! I got my laptop running again! Keep it up! "
Geekman
  • 32281 Answers
SOURCE: compaq presario cq57 PCI drivers
Use a computer with Internet access to download the drivers and then copy them to an USB memory stick. You then insert the USB memory stick inti your Compaq and install the drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Posted on Feb 24, 2012
  • 6771 Answers
SOURCE: compaq presario fan stopping
Take it back to the place of purchase since it is under warranty, otherwise you will damage the processor which the cooling fan protects.
Posted on May 04, 2012
Disk full on "e" drive HP tools
Time for an external hard drive. Prices are excellent for large capacity hard drives too. Down load CCleaner. It's a free program that gets rid of useless files left behind when web surfing. You can pick uo a huge amount of disk space using this program.
Jan 19, 2014 | HP "Compaq Presario Cq57 Laptop Amd Dc E...
Short dst failure disk 1
There is no short cut to fix this. You need to change the disk drive which show this because it is an "end of life" warning
Nov 27, 2013 | Compaq Presario CQ57-339WM
My laptop displays Smart Hard Disk Error please help, it says the following: The Smart hard disk check has detected asn imminent failure.
This error message means you need to copy/backup the data on this hard drive before it fails completely. When the hard drive fails completely you will have to replace it.
Mar 19, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
My presario cq57 wont boot to windows and there are no recovery discs, how can i reformat the hard drive?
the only way to format is using the CD,before formatting download the network drive from HP so the you can download other softwares after formatting
Jan 27, 2013 | Compaq Presario Cq57 Notebook Pc
How do i toggle the mouse pointer on my compaq presario cq57?
Usually on the Presario models there is a very small button just about the mouse trackpad that will disable and enable the use of it. It's usually between the trackpad and the keyboard
Aug 02, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
HP Compaq Presario CQ57-229WM Notebook PC bios password
don't trouble yourself
try this password if you are using compaq
75681807
Jul 25, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Compaq Presario CQ57 has red screen with compaq logo on start up and wont go past that screen even when pressing f-buttons
The hard drive has issues or the windows files have been corrupted, remove the hardware and reseat it back in place sometimes this will activate the system, next! use your backup recovery disc if you have one, no change! the hard drive will need to be tested.
Jun 24, 2012 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario CQ57-229WM Hard Drive Replacemnet Instructions
How old is it did ou call up and see if it was u.Der warranty if so they will send out New one.....if not remove battey and the bottom two covers with little symbols on them to gain access to he
Jun 02, 2012 | HP Compaq Presario Cq57-229wm Notebook Amd...
Compact presario cq57-229 recovery software
You can get a recovery CD from the Compaq/HP WEB site for your model computer.
Dec 25, 2011 | HP Compaq Presario CQ57-229WM Notebook PC
HP Compaq Presario CQ57-229WM Notebook PC Logo
366 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
