Question about Ruud UBHC Air Conditioner
Please help!!!!!!!!!
R UDD model RCHA 24A2AL14,SERIAL M0195 ,MY UNIT GO ON BUT ONLY GIVE OUT COOL AIR ON HEAT SETTING AND ON THE AC THE AIR DOESNT GET COLD AT ALL. THE THEMOSTATE ONLY GO ON MANUEL , PLEASE LET ME KNOW IF IT CAN BE FIX OR DO I NEED TO BUY A NEW UNIT ,...THANKS Margie
  • Perry Putnam
    Perry Putnam May 11, 2010
    Is the outdoor unit coming on at all? What kind of system is it heat pump, gas furnace with a/c?
    Problem Solver:
  • 8 Answers
Sounds like you either have a severe wiring issue or if it is a heat pump there may be a problem involving the reversing valve. I recemmond you have your hvac man look at it.
Posted on Mar 12, 2009
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Ac unit will not heat
You need to check your model # a CP06 is a straight cooling window unit you may have an EP08G10 this is a heat cool unit. Double check your thermostat is turned to higher setting. If so you may have an issue with the heating element or the heat limit on the element.
Dec 08, 2013 | Friedrich CP06C10 Wall/Window Air...
Hello, I have a sanyo ac model # xs3622, c3622 and was wondering if there is a heat setting. I live in a warm climate and have never needed the heat. The remote control has a heat setting but when I...
Your a/c model is only cool, but remote may be heat and cool which normally supplied by all manufacturers. Don't worry. In your remote heat mode will not respond by unit. Helpful advise?
Jan 02, 2011 | Sanyo Heating & Cooling
Window AC Model No. : LG LWA18G 2DF1AK42 IS THERE INBUILT HEATING FUNCTION? HOW TO USE?
Please try to understand with your model, the tonnage and also whether it's cool only or heat & cool. 12,000 (12)...........means 1 TR. with this help your a/c is 1.5 Tr and if it's heat and cool definately there wil be indication in the model cde it self. Ex.......A18TH DF..... like this. There will be H added in the model code itself. Yours is not heat mode. Is it helpful?
Dec 13, 2010 | Amana PTC094B35AM Air Conditioner
How do I change out the fan motor on my LG LWHD1200HR AC/Heat unit., as it needs to be replaced, Im a technician on major appliances, but have never replaced a fan motor on a window air conditioner. any...
Unplug the unit and remove it from the window. Place it on a secure surface for working on it. Take off the cabinet. Remove the fan blades and disconnect the wires at their terminations. unbolt the motor and bring it, along with the make, model number and serial number, to the nearest United Refrigeration or W.W. Graingers. Have the counterman match it up for you. Reverse the above procedures, remembering to replace the capacitor.
Jul 18, 2010 | LG Heat cool Window Air Conditioner
Unit will run if the thermostat is switch on ON, but if left on AUTO unit will hum and won't run.
For most Thermostats on and auto is for the fan switch function. There s usually another button for heat off cool. When you turn a\c or heat on , the fan switch should be on auto.
Jul 10, 2009 | Heating & Cooling
Cannot set a/c to operate automatically
sound to be in heat modenow. If you are after the cool mode, then if you have a cool setting and a heat temp setting, Lower the heat to almost off and set the cool setting to 74 degrees. See if the outside coils get warm. Make sure you are off manualo and n auto. If it runs, give it some time and the tenp of the outside coil will rise and the inside will get cold. Food Luck
May 23, 2009 | Sanyo Split System Air Conditioner
CARRIER AC UNIT
please summit model number and maybe i can help.
Nov 12, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ruud UBHC Air Conditioner Logo
95 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
