Computers & Internet Logo
Posted on Mar 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How computers are able to take the words entered on a keyboard and translate them into digital information.
Michael Thomas
Level 3:
  • Master 3,056 Answers
  • Posted on Mar 11, 2009
Michael Thomas
Master
Level 3:
Answers
3056
Questions
52
Helped
1308156
Points
10935
Hi there
ok here is how it works when you press a key this produces a make code when you release the key this produces a break code a chip in the keyboard processes these codes to produce a scan code that is sent to the cpu the chip determines the locatiopn of the key pressed and sends that location ,together with the irq to the cpu the scan code stores it temporarly into the memory now the bios converts the scan code to the character assigned to the code thus producing a letter in a language depending on the user like english /spanish /ect ect this probably is confusing but this is how it works. hope this solves your question
best regards mike
  • Michael Thomas
    Michael Thomas Mar 12, 2009
    hi there again
    please dont forget to rate this service
  • Michael Thomas
    Michael Thomas Aug 06, 2009
    hello again just checking in to see if you read my post
Casio EX-word EW-S300C Translator. Where is the space bar on my ex word ew-s300c please?
The is a Spanish Translator. Apparently the Ampersand '&' is the space (espacio)
Entering in Spanish• When entering multiple words (phrase search and example search),separate them with an ampersand (&), instead of spaces. Example: tener una de ? tener&una&de• Enter hyphenated terms as a single word, without the script. To search for "Castilla-La Mancha", for example, enter "castillalamancha".• You can enter up to 30 characters. Ampersand (&) characters used in place of spaces are also counted as entered characters.
https://translate.google.ca/?sl=auto&tl=en&op=translate
Here is the manual in Spanish. In Google Chrome, you can Right Click on a computer and choose 'Translate to English'.
manualslib.es https://www.manualslib.es > products ·Translate this page Manuales y gu?as de usuario para Casio EW-S3000. Tenemos 1 Casio EW-S3000 manual disponible para descarga gratuita en PDF: Guia Del Usuario ...
tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 • Computers & Internet
tip
Tips that How to translate your Text file to Other Languages in Microsoft Word...
<span>Now the world has changing into a global village where you have to communicate with people of different culture and languages. We should come across the people who can speak different languages on the internet, and global business market.</span><br /> <p><span>Everybody can't have an access to a professional translator who could do without the help. Because of this reason, word-processing programs are available to fulfill this requirement. </span><br /> <p><span>It is possible to translate your text in Microsoft Word 2007. Microsoft Word 2007 also can be used like any other translation program. In order to translate text in Microsoft Word 2007, we must have to use its built-in function.</span><br /> <b><span>Following steps will help you to translate word text into other languages:</span></b><br /> <span> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); <span> </span>Select the text which you want to translate. If you want to select all document, and it is very lengthy, you can select all page by using Ctrl+A.</span><br /> <p><span>Click on Review button on Menu bar, then</span><br /> <p><span>Click on Translate in the Review tab.</span><br /> <p><span>The task pane will be display on the right side of the document. Select the language which you would like to translate into or in existing language.</span><br /> <span>If you want to translate the selected text into any other language that is no included in the list, then click Translation options and select the particular language which you want.</span><br /> <span>By this helpful feature of Microsoft Word you can translate text in to other languages. However, there is no substitute for anyone or translator as good and meaningful translation. </span><br />
on Dec 24, 2010 • Computers & Internet
Looking for a cross trainer verso 107 user guide, english version.Because i have a NL version :)Anybody?
https://translate.google.com can sometimes translate an entire .PDF or Word .DOC into English from another language. It also permits you to enter words and sentences to get translated versions of text.
1helpful
Have microsoft office 2007 on my desktop ,why is it not possible to translate text instantly ( many languages are set normaly,but non is translating).I have vista
Though MS Office has language support for many languages all this does is provide the special characters and in some cases allows you to use a special keyboard designed for that language. It does not translate text for you.
There are free web sites that will translate text for you (translate.google.com and babelfish.com are only two). You can copy the text and paste it into a text box on the web page. You may need to indicate the languages you are translating from and to. Be forewarned, though, these free translation sites generally offer a word-for-word translation, which usually isn't a very accurate translation.
Hope this helps.
tip
Translate Text to Other Languages in Microsoft Word 2007
The world has become a global village where you need to communicate with people of diverse cultures and languages. We come across people who speak different languages on the internet, or we need to communicate with different people in the global business market. Sometimes we need to translate business documents as everybody doesn’t speak the same language. Students might need to translate some facts as well as information e.g. the history of a specific country into their own language in order to learn about its history.
Everyone can’t have an access to a professional translator who could help them out in this matter. Due to this reason, word-processing programs are available who try to fulfill this requirement. Other than the different programs which fill this requirement, it is possible to translate text in Microsoft Word 2007. The feature to translate text in Microsoft Word 2007 can be used like any other translation program. In order to translate text in Microsoft Word 2007, we just have to use its built-in function.
Follow the given steps to translate word text into other languages:
  • Select the text you want to translate. You can type it there and then or you could paste it from somewhere. If you need to select the entire document, and if it is very lengthy, you can go back to the "edit" tab and click "select all." Or you can just highlight the entire or part of the text by clicking the left mouse button and dragging it across the text you want to highlight.
  • Click on Review button on Menu bar.
  • Click on Translate in the Review tab.
  • A task pane will appear on the right side of the document. Select which language you would like to translate into or the existing language it is in. Here is where you can select which language to translate to or from.
  • The selected or highlighted text will be translated in the lower part of the task pane. You can get the translation of the same text into different languages instantly as you choose the language under the option of "To".
If you need to translate the selected text into a language that is not included in the given list, click on Translation options and select the particular language you want.
This helpful feature to translate text in Microsoft Word is very handy. However, there is no substitute for a human professional translator as good and meaningful translation demands comprehension as well as understanding of cultural references, artistic quality and talent. So there are chances that the translation done by a computer program will lack profundity as well as meaning.
I can only find the spanish version for setting my intermatic 7 day outdoor digital timer. how can i get new insturction--in english.
Intermatic posts manuals in Spanish and English, but not every manual is available.
Here are some choices.
1) Add a comment with timer model number and I'll find manual and post link if manual is available.
2) Go to Intermatic manual page below. Use 'Find' feature on browser (click Edit > Find) to locate model number quickly on page. Manual search takes you to individual manuals or to a product page. When page comes up model numbers show in a vertical row > click model number to view drop-down menu for links to manuals.
Not every manual is available.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
3) All else fails, use google translate. I re-wrote and posted GE yard stake manual today using translator. Enter whole sentences into translator > no need to translate word by word anymore.
http://translate.google.com/#auto'en'
Here's outdoor GE timer translated from Spanish using google translate:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
5) Add a comment and post link where you found Spanish version of manual (as long as it's not a free-manual-with-spyware website) and I'll locate English manual if possible -or- translate manual for you, and post result next day or so.
How do you use the translate on oz-590A?
Word Translator
English-Spanish bi-directional word translator function is available
for download. Refer to "Downloading database" on page 32 for
details.
1. In the Main menu, tap
]to enter the Word Translator Mode.
2. English
Spanish translation is set by default. To change the
translation direction, tap the division arrow, or use
m
and/or
k .
3. Enter the desired source word and press
x. The matching
English or Spanish word will then be displayed.
• When the icon "
j" or "
l" is activated, more letters exist. To view
the remaining letters of long words that cannot be accommodated
on the screen, use
j or l to scroll.
• If there is no matching word, "NOT FOUND!" is displayed. The
word next in alphabetical order will then be displayed.
• Press
to scroll through the word list, or enter a new
word using the keyboard, and press
xfor another search.
Notes:
• If you choose not to download the Dictionary Database for the
English/Spanish Translator, then the extra memory space will be
utilized by other applications.
In such case however, the Word Translator function will be disabled;
tapping the
]icon will display a message "NO DATA!".
To learn how to download the Dictionary Database, refer to the
section "Downloading database" on page 32.
• The downloaded database for this Word Translator is utilized also by
the Spell checker; do not delete the database if you intend to use the
Spell checker function.
5-Language Phrase Mode
5-Language Phrase Mode is available for download. Refer to
"Downloading database" on page 32 for details.
Select an English key phrase to find equivalent expressions in four
different languages - German, French, Italian, and Spanish.
A phrase can be browsed under a traveling situation, or can be
selected from a list of words.
To search phrases in a certain situation
1. In the Main menu, tap Phrases to
enter the Phrase Mode.
2. Select the desired target language.
3. Select the desired scene to
browse the relevant phrases. For
example, select "3. Airport".
4. Tap the desired phrase to select.
Tapping the phrase one more time
to display the entire phrase.
5. Press
x to display the equivalent phrase in the target
language.
The Database menu of the Desktop Utilities allows you to download
database for the Word Translator / Spell Checker, and 5-Language
Phrase Mode from the CD-ROM.
1. Insert the PC software CD-ROM.
2. Click "Download" in the Database of the Desktop Utilities.
3. Select a file you wish to download, then click "Open".
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Information is in Spanish! The instructions for the Multipass 370 on the computer screen are in Spanish How to change to English?
go to the control panel, regional languages options,
add spanish to the list, put English at the top,
tick the keboard boxes underneath the tab, to envoke the keyboard too,(must do)
also you get the offer to put the translator on the notification area or dektop, set this setting too, so you can switch between them easy,
Then select all the text to translate, copy the item to memory, contol A to select it all,
open a word document, switch the language and paste it into the document, you should be good then.
or copy all the text in to memory, contol A,
Then go to google type "free translator" into google, go to the translater, paste all the text into the box, and choose which language to translate to.
Job Sorted.
Regards
Richard.
Keyboard language conversion
Suggest contact Acer for a translation keyboard.
If not available suggest have wife learn American keyboard or assist wife with computer.
Pad Thai food is one of my favorites !
Grand Canyon Tech
Grand Canyon Tech
