Question about Precor 956 Remanufactured Treadmill
Precor 956i no power
Can you help me figure out why my treadmill is not powering on? The plug is working. There is a small red light on the circuit board that is lit. No lights or response on the control panel. Don't see any fuses.
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
maxtreadmill
  • 832 Answers
SOURCE: Hi, my Precor 9.21 treadmil was working fine,
Unplug unit remove motor shroud take a look at incline motor frame assembly, by the sound of it maybe metal fatigue failure disengaging the incline motor itself and could have damage it. This would be my best guess if so contact Precor.
Posted on May 20, 2010
  • 13 Answers
SOURCE: Hi, I'm unsure of the power requirements of the
Most treadmills will do this if you are plugging it into a GFI outlet. Check to see what type of outlet you have it plugged into.
Posted on Oct 05, 2010
SOURCE: Precor 935.i will not power
Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Take care.
Posted on Oct 08, 2010
joeguest2
  • 2080 Answers
SOURCE: While I was running on
First of all, here is a direct link to the ONLINE USER"S MANUAL for a similar model (9.31):
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
If your treadmill is similar enough to the one in the manual, then there are multiple safety features incorporated into the machine. See page 9 and 10 of the ONLINE USER'S MANUAL for detailed instructions on their operation.
Acccording to the manual, TO RESUME RUNNING after the safety switch trips do the following:
Reattach the magnetic safety key to the display console.
Straddle the running belt.
Press QUICKSTART or the SPEED UP ARROW.
If required, enter the SAFETY CODE (which is 1234 unless previously changed by owner).
The belt should begin moving slowly again, so just step back on carefully while holding handles.
See page 50 of the Online User's Manual for more details about the SAFETY CODE to unlock the belt. As stated, the default Safety Code from the factory is 1 2 3 4.
Please comment back here to this page if you have any questions, have difficulty accessing the link, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page. The ratings are important and I truly appreciate your time and consideration.
Thank you very much and good luck.
Joe.
Posted on Mar 01, 2011
Treadmill (Nordictrack T9si) stopped suddenly... Power still being received by controller unit, but display doesn't stay lit so nothing functions
open up the control console and look for loose wires... if no loose wires are found, call CoreCentric Solutions and ask if they refurbish that control board... CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
Jul 06, 2016 | Exercise & Fitness
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
Error code 16 coming up on my treadmill 956i
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Mar 28, 2014 | Precor Exercise & Fitness
Precor 956i
Sometimes a bad MCB will cause a vibration at certain low speeds. If you have another unit, swap MCBs to verify.
Feb 07, 2014 | Precor C956i Treadmills with HR /...
Machine shuts off- says LS
follow this steps and fix it. God bless you
Plug Treadmill into wall outlet and press
START.
Display lights up; TREADBELT DOES NOT MOVE "L5 / LS ERROR"
Is red SERIAL lamp on the motor control
board lit?
Is the yellow RLC lamp on the motor
control board lit?
1. Unplug the treadmill from its
2. Wl alk on the belt manually. (push belt)
3. Does the yellow MOTOR lamp light while pushing?
Is yellow MOTOR lamp on the motor
control board lit?
1. Loose wire connection to motor, capacitor, or choke.
2. Loose brush holder screw on motor. (Check Both)
3. Failed drive motor. Part # 70014 (110V), 70125 (220V)
NO
YES
NO
YES
5.1
5.2
5.3
5.4
5.5
NO
1. Check wiring harness connection between
upper and lower board. Part # 70083
2. Replace display board. Part # 70076
YES
Enter Open Loop Speed mode:
WARNING: NEVER STAND ON THE TREADBELT IN THIS MODE.
1. Turn off the treadmill.
2. Press FAST and START simultaneously and release both buttons once the display lights up.
3. Hold the fast button until the display reads 99.
Short in capacitor, motor, or motor
control board.
NO
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
Sep 19, 2013 | Bowflex Exercise & Fitness
Schwinn 5450 treadmill power to fuse on circuit board, but no operation
HOwever test the c. breaker and reset.
If the problem persist LUBE the deck belt+rollers bearing see the video attached.
see the diagram attached in case that you need to troubleshooting.
Feb 18, 2013 | Schwinn Exercise & Fitness
Fuse looks ok red light lit even without fuse no power to consol
1)Replace the batteries with full charges, with the same mark, do not mix another. with the same polarity
2) Clean the contacts cleaners very well
3) TIGHT THE spring contacts with long pliers for better contacts.
4) Adjust the REED swtich see the diagram, test for open or faulty, clean it, and tigh the connector very well.
5) TGITH the ribbon cables inside for keypds and tight lower connecer display vs lower board connector.
God bless you
Dec 13, 2012 | Nordic Track Nordictrack A2350 Treadmill...
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
Horizon 4000 treadmill is tripping mains circuit breaker and blowing plug fuse
see my personal TIPS and test the motor.
2) the main board can be faulty, replace
3) lube the machine for a DECK belt , the resistance can be another cause.
4) lube the roller bearing too.
5) test the power supply for faulty
see the block.
God bless you
Sep 19, 2012 | Exercise & Fitness
Precor 956 Remanufactured Treadmill Logo
145 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
