Question about George Foreman GFG21 Indoor Grill
My gfg21 griddle stop powering up,what would cause that
When we plug it into the outlet,the indicator light that comes on to let us know that it is on doesnt light up anymore.so would that just b in the cord,or has it burned out.
I have a Hoover Rewind, the plug always got hot, tonight it just stopped working, I know it is not expensive and older but I really don't want to buy a new one if I can avoid it at this moment
I am not sure of the motor wattage but it is unlikely to exceed 2kw and is probably much less so that sort of load being plugged into a power outlet capable of safely delivering a much larger current is unlikely to cause heating of the plug. That the plug did become hot indicates a poor contact between the supply cables and power outlet, between the power outlet and plug or what seems the most likely, between the plug and the power cord.
Given that the plug has been getting hot and that most breakdowns of portable appliances including vacs are internal breaks of the power cord usually at or somewhere near the plug, so that would be a good place to start testing...
Mar 02, 2017 | Hoover Vacuums
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
I have plugged in my new laptop correctly but when I tried to switch it on the laptop does not respond. Is my laptop broken or am I missing something?
Thank you using fixya.
Here are the things that you need to do:
1. Use a different power outlet. Maybe the outlet is bad.
2. Check the ac adapter. check if the light is lit. The light is a power indicator. If there's no power on it, then, you have to make sure that it's not broken or it's connected properly to the power outlet.
3. Check for any power indicators in the laptop. Like lights lit or the charge indicator. If there's none, then, the laptop is not receiving any power. It might be caused by a defective battery.
4. Remove the battery. Plug in the laptop to the ac adapter without the battery on it. Check for power indicators. Press the power button.
Let me know if there's any development. Leave me a message in this post.
Apr 02, 2011 | Computers & Internet
My television just doesn't turn on. It was working fine last night then it stopped working. The outlet works and the red light doesn't come on.
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now,the tv should be working again,if the tv still getting same result no power LED light indication at all or just flashing power LED light indication.Mean ur tv the power supply board is the causes and the problems.The power supply board,that board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 01, 2011 | Memorex MLT3221 32 in. LCD TV
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
When I plug the power cord in the wall outlet, the red light turns on indicating that power is there. when I press the "power on" button on TV or on the remote, the green light turns on for one...
Right now the standby 5vdc is working but it may have gone into safety shutdown due to failed power supply or shorted circuits in the backlight inverter board. You need to troubleshoot it to narrow down the causes first before buying the wrong parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 01, 2010 | Norcent Technologies LT-2722 27 in. LCD...
I have a Viking Professional VGRT Gas 4 Burner + Griddle Cooktop. The griddle stopped working all together. The burners still all ignite and work fine. The griddle does not heat up. When we turn the...
I just had a tech come to my house and he told me that I need a new glow plug, It's the box to the right of the flame. Looks easy to replace, his visit took 5 minutes and it cost me 143.95 (this doesn't include the cost for the part or to have him come fix it, that will be sometime next week) so if you can get the part and do it yourself I would suggest that.
Jul 29, 2010 | Microwave Ovens
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
George Foreman GFG21 Indoor Grill Logo
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
