Question about Bosch Dryers
Bosch heat pump clothes dryer smells - Bosch Dryers
  • 1314 Answers
SOURCE: Dryer heats up but isn't drying properly
yes it does something is blocking your vent either its all coiled up behind the drier or something i need to ask a few questions go out side and look at where your drier vent has a hood make sure nothing is blocking it from opening it has a little round door on it ive seen some that have little plastic screens on them that gets clogged the screen is there to keep critters from building nests in the vent line then get a flash light and look over the back to see if the vents folded over mashed etc to find out if its a vent problem take your vent loose dry a load and see if it goes back to normal if all that's ok get back to me and we will clean the drier i need to know if your lint screen is on top or in door and your model #
Posted on Jan 02, 2008
SOURCE: Maytag dryer does not maintain heat and clothes smell
Save yourself the repair call and replace the gas coils. They're a $30 part and it takes all of five minutes. Works like a charm.
Posted on Oct 08, 2008
  • 61 Answers
SOURCE: dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Posted on Dec 18, 2008
kram26
  • 544 Answers
SOURCE: Dryer is heating but smells like something is burning. Clothes stink
HI,
i stronlgy suggest you that dont use it if you are smelling a un usual scent like burning wires.
to prevent any accidental that may occur.
bring your dryer or call a service technician to check parts by parts maybe some are only short circuited.
thanks,
Posted on May 28, 2009
  • 75 Answers
SOURCE: dryer drum stopped when too wet of clothes were put in
you have to raise up the top and the drum will just pull off the belt is only about a 1/2 inch wide like a piece of leather possibly laying on bottom under drum
Posted on Jul 03, 2009
How to fix a smelly Bosch Washer/Dryer?
If door seal has black spots on it, like mould marks,,, change seal and clean out using bicarbonate of soda on a 90 degree wash,,,,, no powder or clothes obviously
Jun 13, 2013 | Washing Machines
Our bosch exxtra clothes dryer runs but there is no heat
no heat use multi meter and check the hi lo limit and cycling thermostat aswell as the heating element for continuity. the thermostats are located on the heating element and one on the blower. Another thing to check and see is there full 240 volts at the outlet and terminal, if ur only getting 120 you will have enough to run the motor but not the heater?
Aug 12, 2012 | Bosch Dryers
My Bosch tumble dryer is not heating and the clothes are not drying....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 21, 2011 | Bosch Dryers
Dryer is not heating to dry clothes
if its not heating at all, first check electrical and make sure your getting 220 to the dryer if you are more than likely its the heating elements, check them and replace if bad
Apr 26, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Clothes smell burndt after drying in a Kenmore gas dryer
Rule number one NEVER EVER use the top of your dryer to stack piles of clothes while in use. That is the main reason why dryers over-heat. Also clean out the exhaust tube to the exterior.
Feb 21, 2009 | Kenmore 73952 Gas Dryer
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
56 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
