Question about Amana Dryers
The dryer drum is making a noise like it's loaded with bricks
I took perfectly working dryer from shed, and put it back in garage to use. Plugged it in and started it. Forgot to check inside dryer for empty jaegermeister bottles and crown royal bottles. After removing broken glass and still intact bottles, when running dryer it sounds like the drum is out of kilter or off balance or something. I removed the back panel to expose the drum but it exposed nothing. Do i need to get to the drum through the front and top of dryer! If so, how do i go about it.
  • 1 more comment
  • mcdonnell061 Mar 12, 2009
    not really, it just tells me how to expose the drum. when i get to the drum, then what do i do to fix the problem
    after i expose the drum, then what. how do i fix the noise.
    thanks slowride5551, that was very helpful. I'm gonna get started on it now.
    Problem Solver:
  • 16 Answers
The top pops up from the front and then you will have access to the drum by removing the front.
Posted on Mar 11, 2009
  • Slowride5551 Mar 12, 2009
    At this point you will have to physically inspect the drum and the rollers it spins on. To remove the drum you will have to work the narrow belt towards the rear off. Once off, the drum basically sits in there. You will have to pull it forward a bit then up and out. You will see towards the rear a felt type gasket which holds the heat in. Try your best not to damage it.
    At this point, without sitting in front of it, is all the advice I can give you. It's pretty simple as you will see once apart. A large, belt driven, drum that rides on rollers with a felt gasket which seals and centers in at the rear. You should be able to see any problems from that point.
SAMSUNG steam moisture sensor front load dryer has noises coming from it. Need help to pinpoint possible problems and how to fix.
You may have a roller out of alignment or off track with the drum now if you took the front panel off. Check to make sure the rollers are on track and the front slides may need t o be replaced if your dryer is a 2 roller model.
Feb 08, 2017 | Samsung Dryers
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Dryer makes humming noise drum won't spin just goes back to pause
take out the plug and change the capistor ..make a note of the wires and take picture where they go
Aug 05, 2014 | Electrolux EIED55HIW Electric Front Load...
Maytag Dryer- Drum not rotating (belt and motor both work)
I surely do hope this fixes it all.
The pulley that fell apart is supposed to. Well, not quite. It is not fastened inside the machine, and comes off easily. It is the belt tensioner. It fits into 2 slots on the bottom steel panel of the machine (The base)
You will be finding it is a pain in the neck to put back on, but you can do so. The belt goes with the grooves toward the drum, not away from it. The belt goes in a S shape around the motor pulley and the tensioner pulley. One you put the tensioner back in it's place nin the two slots, you will push (or pull) on it against the spring arm to "bend" it so as to get the belt back on.
Be blessed.
Jun 19, 2013 | Maytag Dryers
I have a Kenmore Series 70 Electric Dryer and I just got done doing some repairs which required pulling the drum. Now when you put a large load of wet clothes it makes a rubbing noise when it is running
when you pulled the drum on this dryer, everything has to go back exzactly as it came out, make sue you set the drum back rt and did not leave any screws out, and or the bracing not right if you changed the belts it will probally be the way you put it back the drum check your work youll find it
Feb 18, 2010 | Dryers
Dryer making noise and quits running
You may need to replace the drum rollers and front drum glides. The motor definitely is bad and should be replaced.
A Maytag dryer is worth investing the repair cost.
Nov 12, 2009 | Maytag Dryers
Dryer has a banging noise
It Is fixable.All you need to is try to balance the load or a perfect concrete flat surface for the machine.
If the problem still persists, then during the previous vibrations, the shocks or the drum bearings might have been damaged, you might have well replace them to avoid further problems.good luck.and please post your comments.
Apr 11, 2009 | Whirlpool Dryers
I have an LG TDC70080E condenser tumble dryer. It has worked perfectly for 2.5 years and now is playing up (suprising, considering it is just out of warranty!) There are two issues: 1. The drum is not...
My pump started making a loud noise and stopped pumping, I removed the pump and found that the impeller had moved down the shaft, so I put some locktite on shaft replaced impeller and its fine now
Oct 28, 2008 | Dryers
Drive belt and noises.
your drum shaft is broken this is making the pulley wobble causing the belt to come off and it will also explain the noise. This is a very expensive job sometimes requiring the complete tub to be changed might be time for a new machine
Jul 30, 2007 | Bosch Classixx WVF 2402 Front Load...
Dryers Logo
338 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
