Question about Broan-NuTone 0521B000 RELAY FOR CV350
Nutone relay board assembly 0521B-000 Where is it in unit and how do I replace it?
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Nutone CV 450
If the top comes off, it will be by the motor and exhaust. Just replace it with the new one, make sure you don't mix up any wires. Also unplug it from the AC first.
Posted on Jun 22, 2008
SOURCE: I need a relay board for a Nutone CV 450 12.6 amp
Why not just replace the relay? Part number 1094117...
Posted on Sep 02, 2009
  • 26 Answers
SOURCE: Nutone CV353 does not shut off, think it is the relay board
You probably have a stuck relay. You can try tapping with medium force next to where the low voltage wires are attached to the unit using the handle end of a hammer. Even if this works it's time to replace the circuit board. Take the unit to a local vacuum repair center for service.
Posted on Jul 07, 2010
Our exhaust fan is really noisy. Nutone QT 100N-B model. Where can we purchase a new one?
This model has been discontinued but replacement motor assemblies are available. There is no off the shelf model that will fit in the existing housing. If you do not want to replace the housing then the motor assembly is the way to go.
You ca purchase the replacement from either site below:
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
Jun 07, 2011 | Broan-NuTone QT100L Fan
I have a Nu-tone 8663 RP Combo fan and light. The unit has been a great unit for a good number of years. The fan is shot. Motor bearings I think. How can I get a replacement fan assy. ?
I just ordered a replacement fan motor for this same exhaust fan. I got it from here, http://www.electricmotorwarehouse.com/aosmith/nutone/nutone1.htm
It's this one,
1.2 amps, 115 volts 60hz
1550 RPM; Shaft 1/4" x 1"
Rotation = CCW
3.3" Diameter Motor
2 Mounting Studs Opposite Shaft End
Motor Case Length 1 15/16"
2-Prong 115 Volt plug
For Model 8663RP, 8673RP
8664RP (86933-000)
86933000, JA2B104N, JA2B104
can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
Oct 20, 2010 | Broan-NuTone N-8663RP Combination Light...
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
Jul 24, 2010 | Broan-NuTone QT100L Fan
Jun 26, 2010 | Broan-NuTone CV353 Central Vacuum
Nutone Scovill 350 will only turn off if unplugged
Some units have an on/off switch on the power unit itself. Check to make sure that is not turned on. Unplug your power unit and remove the 2 low voltage wires (not the power cord itself) . The low voltage wires start at the unit and run throught your home and attach to each hose inlet. They are usually attached to the unit by simple wire terminals or wire capped to small wires coming out. Just unlug the terminals or unscrew the wire caps and pull the connections apart. Plug your machine back in. If it still comes on the problem is the relay or circuit board/switch/ relay assembly inside the unit. If it doesn't come on with the low voltage wires unattached then you may have two wires touching somewhere in the low voltage wiring.
May 14, 2010 | Broan-NuTone CV353 Central Vacuum
Central vac will not turn off
You have a defective internal relay on the vac. Check for warranty coverage as this is a common occurrence on these big box store units.
If beyond warranty the relay should be a straight forward unit, miniature circuit board type plug in device. Find a Broan Nutone service center or take to vac pro shop for parts.
Nov 01, 2009 | Broan-NuTone VX475 Bagged Central System...
I need a relay board for a Nutone CV 450 12.6 amp dual motor vacumn unit. Where can I locate one? Part #??? Unit will run by itself, then shut off. Unit wll not run at all. It has a mind of its own....
Unfortunately I don't have a part number for you, but you can call this number 1800.322.2965. Tell them you need a new relay board for your system and they'll be able to help you. They cost around 99$. for anything else you might need, go to www.thinkvacuums.com
Sep 01, 2009 | Broan-NuTone CV450 Central Bagged Central...
Central vac won't turn off unless we unplug
Jul 18, 2009 | Broan-NuTone CV350 Central Vacuum
Nutone CV 450
Jun 22, 2008 | Broan-NuTone CV450 Central Bagged Central...
Light won't shut off
I have never reaplaced anything on the control board. But it is definetly the control board that is defective.
Part# R111638 = $110.00
I do service calls for broan-nutone.
Inventex.com
Nov 11, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone 0521B000 RELAY FOR CV350 Logo
46 people viewed this question
Top Broan-NuTone Home Security Experts
Lawrence Oravetz
Are you a Broan-NuTone Home Security Expert? Answer questions, earn points and help others
