Question about Dryers
Heat not confined to tub
I reassembled my dryer after replacing bearing and now dryer is hot around dials at top of dryer. I have a frigidaire heavy duty dryer about 12 to 15 years old.
  • David Shaub May 11, 2010
    You didn't get the heat tunnel connected correctly. Take it apart and make sure everything is tucked in where it goes. The bottom of the tunnel and the exhaust port will be the areas of interest.
    Problem Solver:
  • 6 Answers
You should check the drum seal, front and rear. Also important is the dryer venting. If the vent is restricted by a kinked vent hose or run an excessive distance as is the case in most apartment homes and conduminums
Posted on Mar 11, 2009
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Top of dryer and the back panel get too hot.
Of course they get hot, that is normal.
Jun 30, 2017 | Frigidaire AEQ6700FS Dryer
Grinding noise-- on and off.
This is probably the front AND/OR rear bearings. The front bearing
is felt with slides and fits around the front of the tub.
The dryer has to be disassembled to get at either one.
See if the top panel has hinges in the back if so then all you have to do is raise the top panel to look at the front bearing.
If this was helpful please rate me.
Leo Ponder
imufo2@sbcglobal.net
Aug 02, 2010 | Hotpoint Dryers
Dryer squeak and back panel is hot? Frigidaire Dryer FDE436RES1
It sounds like you have a rear bearing bad.
as far as over heating check the vent line. Your thermostats are ok or your high limit would blow and you would have no heat.
Sep 01, 2009 | GE DBXR463EDWW Electric Dryer
Tub bearings
The bearing block does wear out on these. Replacing it is not an easy undertaking. You have to remove the top and the front of the dryer. Check the drum seals at this time as you have it all apart it is a good time to replace those also.
Eric
Jun 29, 2009 | Kenmore Dryers
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
