MY RCA L46WD22YX5 TV is flashing 5 times then pause
Slinteriors
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
Slinteriors
  • 8617 Answers
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
Posted on May 23, 2009
  • 20 Answers
SOURCE: stanby light flashes 5 times breif pause then
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Jul 20, 2009
Slinteriors
  • 8617 Answers
SOURCE: rca hd52w59 tv. power light blinks three times in
Thats usually caused by the CP150, CP114 and CP120 capacitors which will need replacement. You can get that repair kit at www.tvrepairworld.com and the kit contains the CD with instructions for the repair.
Posted on Dec 14, 2009
diodeic
  • 1622 Answers
SOURCE: my rca tv power light is flashing it flashs 9
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Thanks for using fixya............
Posted on Aug 16, 2010
I have a RCA TV Model L46WD22YX5 it will not read any channels with an antenna, HELP!
The whole USA (years ago now) converted to digital TV signal format from analog (which is what your TV uses), this means that the TV will not pick up any channels without a digital to analog converter box, you can buy them very cheap on eBay.
Nov 24, 2016 | RCA Televison & Video
How can I fix a 46" RCA 720p LCD hd TV flat panel TV model # L46WD22YX5 that has good picture but always flashs
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 14, 2015 | RCA Televison & Video
42in Lcd RCA tv will not power on, the indicator light is flashing red 5 times then a pause then repeats
Hi Ruth, Im having the exact same problem. Ive read online that it is a fuse or something, not sure, but its the weekend, and i have no tv. Tried calling RCA cant get anything out of them. If you find out what it is please let me know. I know how frustrating it is...
Sep 21, 2010 | RCA L42WD22 42 in. LCD Television
Power button flashes three times pause it does
problem solved with an inhouse repair man
Dec 16, 2009 | RCA Scenium D34W20 34" TV
L46WD22YX5 ONLY USED TWICE SCREEN INSIDE LOOKS
Yes it can be replaced but it usually cost more than the set is worth. I checked and the retail plus shipping from my distributor is about $700. That doesn't include labor to install. I would say it would probably run about $800-$850. Good luck and I hope it works out for you. Thanks for using fixya.
Nov 06, 2009 | RCA L46WD22 Television
L46wd22yx5 rca tv lost sound thru tv speakers, sound works thru home theater system...? no other problems seen...
Verify first in the audio setup on screen menu that the speakers are not set to OFF. Otherwise you may have bad power amp sections.
Nov 02, 2009 | RCA L46WD22 Television
Flashes/blinks 9 then 5 won't turn on.
Check the CRTs . That model was notorious for laser like cuts right around the neck by the yoke. I just had one today doing the same thing. The CRTs are no longer available so the set is scrap. I hope that's not your case. Let me know.
Oct 20, 2009 | RCA D52W23 52" HDTV CRT TV
Power light flashing????
Count your flashes and call the RCA hotline and they will be able to tell you what the number of flashes says about your tv. My lamp needs replaced and I was told 3 to 5 flashes meant the lamp was out.
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
Electro Med Services...
