Question about Conair Handheld Fabric Steamer - GS15RN
Turns on and heats up but steam will not come out
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Bosch TDS 1445/05 Sensixx station doesn't making steam
HI!
I HAVE AN Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL. I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK. THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
Oct 06, 2012 | Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
My iron rowenta leaks when before and after i!m iroeing
my iron is different to yours but i used to have leaks as well.
for me it was because i have a heat setting dial that indicates that the steam function is activated when set to a very high temperature.
i also have a push lever on the top of the iron that controls how much, if any, steam is produced by the iron.
the amount of steam is regulated by letting more or less water through to be vaporised by the heating element.
if the heat setting is low and the steam setting has not been switched off then water is being allowed through but the element is not hot enough to vaporise the water. the result is water pooling and either dribbling through onto the clothing you are ironing or running off when you sit the iron up.
maybe it will help if you turn the steam setting off while the iron is not in use.
Jan 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Singer steam press csp-1 iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Mar 03, 2009 | Singer Electronic Steam Press Iron
Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Sep 10, 2006 | Euro-Pro Steam Generator EP8020 Iron
Conair Handheld Fabric Steamer - GS15RN Logo
110 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
