Question about Mitsubishi L75A91 75 in. LaserVue HDTV
Mitsubishi 75" laservue will not power up. Red led in the front is on.
Ran for 30 minutes last evening then blanked out and will not come back on.
2 Suggested Answers
gopakumarg43
  • 74106 Answers
SOURCE: Cannot power on TV.
Error code [66]. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Feb 22, 2014
Hi i jave a mitsubishi L75-A91 and my hdmi ports have stopped working how can i fix this
Try a factory reset. If it do not help you, check and replace its main digital board.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 16, 2016 | Mitsubishi L75-a91 75 1080p Laservue Hdtv
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
TV WILL NOT TURN ON AND RED STATIS LIGHT IS ON NO CODES ARE SHOWN. WHAT DO I DO?
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp. Keep in mind that some off-brand lamps may only last a few weeks, so replacing a relatively new off-brand lamp may unfortunately be necessary.
Apr 04, 2015 | Mitsubishi Televison & Video
Cannot power on TV.
Feb 22, 2014 | Mitsubishi L75-A91 75-inch 3D Ready 1080p...
Mitsubishi L75-A91 colors are breathing..Mostly white color..
Mine is the same way man, what alot of money I have wasted on this, lasts 1 year due for maintence
Jul 11, 2012 | Mitsubishi L75A91 75 in. LaserVue HDTV
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Dec 19, 2008 | Apple Power Mac G5 Desktop
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
PD523 no picture, led blinks
Hy !
Seems to be the colorwheel. When a segment is broken, the unbalanced wheel causes vibrations. Costs approx. 100-150$. Take away back and top so you can see if wheel is not complete.
Good Luck!
Jul 07, 2008 | Acer PD523 Multimedia Projector
Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Jun 14, 2006 | JVC AV-K29MX1U 29" TV
Mitsubishi L75A91 75 in. LaserVue HDTV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
