Question about BenQ Office Equipment & Supplies
Sp890 fan not working
  • 28 Answers
The fan is a brushless fan and very reliable but they do go wrong check to see if you have the supply to the fan assembly there are usually three wires two are the supply the other is the speed control wire tacho run the fan on a separate supply and see if the fan runs before you start checking the voltage on the mother board first.The most common fan for failure is the exhaust fan or heat output fan because it is always mounted near the lamp assembly and bearings do not like heat
Posted on Apr 18, 2013
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Dodge Stratus R/T fan doesn't come on while car is running and car is getting hot.
FAN NOT WORKING
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.
Test volt at fan relay and fan motor.
For more help, I suggest you to go through the troubleshooting links mentioned below:-----
Click the link below: ------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
These will help.
Thanks.
Nov 27, 2012 | Cars & Trucks
Fan won't work
Bother are to be inspected.Test volt at fan relay and fan motor.-------------
For more help,i suggest you to go through the troubleshooting links mentioned below:-----Click the link below:------
------------These will help.Thanks.
2004 grand marquis fan quit working..replaced fan but still wont work
is this the blower motor fan for you heating and A/C or the cooling fan cooling fans have a relay blower fans are fused but controlled from switches inside as well as fuses
Aug 27, 2012 | 2004 Mercury Grand Marquis
Ceiling fan won't run but the light does work. Fan has worked in the past but now just the light works. Why would the fan not work? This is a Hampton Bay Northport III ceiling fan ( product of Home Depot)
mcdevito75 here, You say fan worked in the past, That tells me the fan has not run in over 1 month if so, try this. First, the fan motor is a sealed unit, without running the fan in over 1 month it may be a little stiuck, put the fan lights on, and pull the fan chain just once and turn the fan blades themselves just a little to get thm started. also verify fan switch itself is good, Chain switch should have the familiar click click to it. If not the fan swich could be bad.
Jul 20, 2010 | Hampton Bay 52 In. Northport II Fan, BN
Fan works but light does not. bulbs are good.
mcdevito75 here, The lights should work from the wall light switch and the fan from the pull chain on the fan itself. The fan and the lights come off the same wall circuit so if the fan works, so should the lights, however in the fan assembly itself 1 wire was for the lights and 1 wire was for the fan. You'll have to pull the fuse to that fan, and remove the cover to the fans wireing at the ceiling., Now you can see the fans wireing, I'll bet the wire to the lights has fallen offf due to the vibration of the fan. Hook up the loose wire and the lights should work. If you can"t do the work, look for a handy man in your building / Area.
Jul 19, 2010 | Hunter 20531 Vista Brushed Nickel Ceiling...
One of my fan is not working 1999 Honda Accord
Which fan is not working, A/C or Radiator? Check fuses, if good disconnect fan plug, direct wires from battery to fan to check fan, if fan does not work change. If fan works check water temp sensor for radiator. A/C fan only comes on when A/C is switch on. Like wise radiator fan only comes on when water reaches a certain temperature.
Jul 05, 2010 | 1999 Honda Accord
Fan don't work when power is turn on crown xti 4000
the fans on these amps are heat sensitive, only when the amp heats up, then they come on
Mar 27, 2010 | Crown XTi 4000 Amplifier
LIGHT AND FAN ARE NOT WORKING. HAMPTON BAY LIGHT IS NOT WORKING
Could be a loose wire up inside the fan. I would be very careful in its use. Might I suggest getting an electrician in to resolve this issue. You do not want to battle a fire over a fan light issue.
Aug 28, 2009 | Hunter Ceiling Fan Light Remote Control
Intermittent operation of interior fan - isuzu kb/trooper
fan speed resistor block blown if fan works only on full speed (because power goes directly to fan on full speed, not through resistor)
if fan doesnt work on full speed check for power at fan on full speed with test light if power there fan faulty
no power check switch bank assembly
Aug 06, 2009 | 1999 Isuzu Trooper
262 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
