Question about OKIElectric OKI Electric Oki B930N Laser Printer 62429901
Code Flash Error Firmware okidata B930n
I need reper ... woo i need in dthis cass
OUR RICOH MPCW2200 MACHINE SHOWS SC992-00 ERROR
SC992-00
An error not controlled by the system occurred (the error does not
come under any other SC code).
Software defective
Turn the machine power off and on. The machine cannot be used
until this error is corrected.
Re-install firmware
So try flash firmware. tell me if you need help for that
Oct 05, 2017 | Ricoh Office Equipment & Supplies
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Hp laserjet 1536dnf error 79
Error 79
Software/drivers, Memory PCA's, Font-Macro-Personality Cartridges, option I/O Cards. Defective toner cartridge in the Laserjet 4 Plus only. Remove any accessories (font cartridges, memory PCA's, SIMMs, etc.) plugged into the formatter card and try again. If the problem persists and is application specific, verify proper setup with application vendor.
Defective Formatter PCA - Replace with known operational board and try again.
Firmware Update - The configuration page lists the firmware version of the product. Depending on the model, a firmware
DIMM may need replacing or a flash update. On flash-memory-based products, you can update the firmware code by downloading the latest flash executable file for the product and running the program according to the readme instructions posted with the update file. If the firmware should become corrupted or fail (usually because of an interruption when attempting to update the firmware), the product will no longer function. In this case, a firmware recovery DIMM is available.
Reseat DIMM, then Formatter - Replace or flash DIMM then formatter
Can this also be?
Jan 03, 2012 | HP Laserjet M2727nf Multifunction Printer
Hello l have a okidata b930n whit the error in the display " panel locked " l can't access to the panel control, how can unlocked to get access thanks.
Hello!
You can go to Technical menu and reset to factory defaults!
To enter on tec menu restart the unit and press the menu button and right key on same time that you turn on the unit and get pressed the both (2) buttons.
Best Regards
Nov 12, 2010 | OKI B930n Laser Printer
Hi we have a okidata b930n whit the " panel locked " error we can't use the panel control. thanks
Panel locked message is set to prevent changes in the unit. Your IT person probably locked it. You may need a password to remove the lock. Neither manual gives a reset method.
See page 147 in the reference manual:
http://www.softcom.cz/Files/00067013-00488709.pdf
User Guide:
http://www.ta.cz/common/download/OKI_N_B930_ENG.pdf
You may have to call or email Okidata:
www.okiprintingsolutions.com/us support@okidata.com 1-800-OKI-DATA
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2010 | Office Equipment & Supplies
How do i clear an error alarm on my okidata 320? it wont do anything.
Power on then off, then unplug the unit for a few minutes. Then try it.
If this does not work post back.
Feb 05, 2010 | Matrix Okidata Microline 320 Printer
Error 79 ...shuts off and the screen says error 79
Hi angelahender:
Here is your problem.
79 Error
PowerOff>PowerOn
The product has experienced an
internal firmware error.
Disconnect the power cable from the
product, wait at least 30 seconds, then
reconnect the power cable and wait for
the product to initialize.
If the error persists, upgrade the firmware.
Firmware update via flash executable
The configuration page lists the firmware version of the product. On
downloading the latest flash executable for the product and running
the program according to the readme instructions that come with it. If
available from HP.
Hope this helps
Jul 16, 2009 | HP LaserJet 3330 All-In-One Printer
Error Code: 3271
SONY DSR 45
ERROR CODE 3271
Oct 16, 2008 | Sony DSR-45 Mini DV VCR
OKIElectric OKI Electric Oki B930N Laser Printer 62429901 Logo
173 people viewed this question
Top OKIElectric Office Equipment & Supplies Experts
jasbo
jasbo
Are you an OKIElectric Office Equipment and Supply Expert? Answer questions, earn points and help others
