Question about Sony PlayStation 2 (PS2) Console
''the wide strip connecting from the inside cover of the ps2 came out where does it go'' Problem
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 273 Answers
Is it silver? does your system turn on? if not, that 'wide strip' powers your PS2. if you have a fat PS2, go here and go to the very end. hope this helps. www.powerfulguides.com/ps2
Posted on Jun 11, 2009
Canon MP210 printer: There's a 3/16" wide by 16"
Hello.
Yes. That is the encoder strip.
Gently connect the strip on either end behind the carriage rod. The strip has an "L" on one side and a dot on the other. Be sure you put the "L" side on the left. There is a small **** behind the printer head that you must slide the encoder strip through before attaching.
After connecting, if the strip needs cleaning, moisten a clean cloth or tissue with water, then gently grasp the strip between the thumb and forefinger, and carefully pull the moistened cloth along the entire length of the strip in a right-to-left direction. Repeat this step with a different portion of the cloth to ensure that all foreign matter is removed.
Allow the encoder strip to dry, or gently dry the encoder strip with a clean, dry cloth or tissue. Position the cradle near the center, and then plug the power cord in the printer. Close the top cover to allow the print cartridge cradle to move bac.
Hope this helps.
Nov 05, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
The console works (comes on , tray opens and closes,) after putting disc in tray and closing it makes a sound like disc reading then stops ,nothing on screen ,,Is this a replace the laser job??
its not dealing with the laser. your cord inside connecting your ps2 top cover to your tray might be lose or not connecting like it should. take apart the ps2 and see if it is connected. if not place it back inside the tray slot inside of the ps2.
Dec 15, 2009 | Sony PlayStation 2 (PS2) Console
Tape strip came deattached
You can't. That strip is more or less a wire. You'll need to replace the whole laser assembly.
Nov 20, 2009 | Sony PlayStation 2 (PS2) Console
My Ps2 wont turn on
take the ps2 apart and take the disc tray out the strip connects under it
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
Loose wire in the PS2
It is located on the right side, underneath the CD Drive.
Nov 27, 2008 | Sony PlayStation 2 (PS2) Console
When I turn on my tascam 2488mk there's a message that reads...Cannot book!! Not detect hdd correctly please power off and check h\w.
well id say the hard-drive is not properly connected inside the computer to the motherboard. usually two cables that connect it one looks like a strip of mutiple wires usualy wide, and the other is a power cable that connects to the power supply. try removing the strip cable and reinserting it.
Aug 03, 2008 | Computers & Internet
Paper jam problem
Hi, if you are having the paper jam issue , then unplug the power adapter and remove all the papers from the paper tray and if you closely look inside the input paper tray you will find rollers , move the rollers with your finger tips. open the printer cover to the extreme left you will find the cartridge holders , move the holder from left to right a couple of times , behind the cartridge holders you will find a transparent strip which is inch wide and is inch wide and firmly connected at both the ends, use a damp cloth and clean that strip . lift the printer an#d shake it firmly turn the printer upside down and gently tab on the base , look for any obstructions.
Try all these steps and if there is an issue then you have to purchase the new printer.
good luck :), let me know once you perform all these steps
May 01, 2008 | Dell 924 All-in-One InkJet Printer
My ps2 wont play games
firstly, have the appropriate tools. tools include:: standard philips, jewelers philips(tiny screwdriver), a ziploc baggie, a q-tip, and hydrogen peroxide. open the ps2. there are 4 or six screws depending on the model. the screws are on the bottom. the screws have covers so take them off. Once the screws have been removed, remove the top cover. Again depending on the model, thier might be a strip connected to the top cover going to the reset and open buttons(so be CAREFULL). If u have a older model then this part will be more difficult. on the right side of the ps2, thier should be four screws holding the top of the cd reader down. remove the four screws and pull the top off. now inside the cd reader, thier should be two axle like metal poles going horizontal. This controls the laser so it can move back and forth. dust usually collects on these. clean these off, but make sure thier is still some grease on them. if u mess this up u can go buy ps2 grease. now finally to the fixing of the eye(laser). get a q-tip, dip it in a bottle of hydrogen peroxide. use the wet side and gently rub the eye(laser). then take the dry side of the q-tip, and dry the eye(laser). if u want to test the ps2, but u dont want to put it all back together, u can just set the cover back on. or (i wouldnt suggest this) u can take the white magnet out of the top cover and place it on the center reciever. it worked for me so i hope it works for u.
Mar 15, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
