Question about Vacuums
Blown fuse of electrolux ultraactive vac - Vacuums
I have a new Electrolux 4300A (Ultraactive Deep Clean Canister) and the powerhead brushruoll has stopped working. Where is the reset button?
I have repaired many of these and to be honest your best course to to call Electrolux Home Care and find your nearest warranty station. The reason for this is it should cost you nothing and without the on ohm meter and a prior knowledge of how these are put together, you would not be in for a fun afternoon. Call them and explain the problem, most likely you have a broken or pinched wire in the neck assembly and will need a replacement. The wires to the neck attach directly to the main circuit board near the height adjustment, but to retain your warranty call Electrolux now... put down your mouse and call them so you can go back to enjoying your recent purchase with confidence.
(800) 896-9756 Monday-Friday, 9AM-8:30PM (EST)
Saturday-Sunday, 11AM-7:30PM (EST)
Nov 13, 2013 | Electrolux 75922-4 Beam 045056 Power Head
Heppa filter pops off when I turn the vacuum on
Did you replace the exhaust air diffuser? That's the plastic type vent housing the hepa filter was under.
Oct 12, 2013 | Electrolux UltraActive Turbo Bagless...
Remote control Electrolux flashes 3
Can you give more information...what model and what is happen.
Aug 23, 2013 | Electrolux UltraActive EL4300A Bagless...
Ultraactive vaccum filter keeps popping off
There are two possible causes for this issue. The most likely is that your exhaust filter is blocked and so the air literally cant get out. You need to replace the exhaust Hepa Filter every six months anyway so get a new one and see if that fixes the problem. If it still is popping off after this it means the tiny lugs on the filter cover are damaged so you will need to get a new one of those.
Jul 11, 2013 | Electrolux UltraActive Turbo Bagless...
Electrolux ultraactive vacuum won't start
Hi There, The E2 error is caused by the terminal block pins where the hose plugs into the vacuum become bent out of shape. This is the receiving pins at the front of the vacuum on the inside. If what I am saying is confusing then it probably needs to go to a technician, it is a 10 minute job to fix if you have done it before. There is also a slim possibility that you may need a new hose for it too. If you are in Melbourne I can fix it I run the VacuumSpot business.
Jul 06, 2013 | Electrolux Vacuums
Hi there my electrolux ultra active is flashing 3 E on the remote screen. What is wrong with it?
my electrolux ultraactive vacuum won't start & is flashing between 2/3 on the remote. I've empty the canister & checked filters etc. It's band new I've only used it three times.
Dec 07, 2010 | Electrolux Vacuums
I was given an Electrolux vacuum model 1401-B. I would like to download a manual for it. Do you have one? Thanks, Carolyn
Carolyn, The 1401B is one of a family of US built LUX models , now sold by AERUS Electrolux. It shares common info with the MARQUISE, Super J , Olympia and 1205, etc so if you come across a used manual for any of them you will be in good shape.
Try an AERUS Electrolux dealer but the manual may be out of print.Also try a local vac shop
Quick rundown, :
Set the dial at front between medium and fine and don`t adjust, this is the bag fill control, NOT a suction control.
Only use genuine 4 ply filter bags from a pro vac shop, not grocery store grade as this is a vac which filters thru its bag.
Hang the hose for longer life, obstructions can be blown out thru plugging the hose in the blower port under the slide door behind the handle.
Inspect the power head for hair and thread and remove any visible.
When you wheels squeak while vacuming spray the axle shaft behind the neck with a drop of WD 40.
If you feel air venting thru the hose behind the handle or if it is crushed and kinked there or at the vac replace the hose for better suction. The weight of this vac weras out hoses. When the castor below the body cracks and it will, match it with a small SHEPARD castre at the hardware store.
If your rewind is sluggish, pour a tablespoon of talc or baby powder in a tissue and run it up and down the lenght of the vac cord end to end. Then drop the tissue into the vac bag fro fresh scent.....
Enjoy the vac, this one is a great one 30 year plus life span, parts are still available keep it in good repair
Oct 10, 2009 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
