Question about Vacuums
How do I remove a cyclone rake impeller?
I have the engine removed and am ready to replace it, but can't figure out how to remove the impeller from the engine so it can be installed on the new engine.
2 Suggested Answers
grumpytoolgu
  • 69 Answers
SOURCE: my cyclone rake impeller dissintegrated... Nedd a new impeller...
Try calling the factory at :
Woodland Power Products, Inc.
72 Acton Street, West Haven, CT 06516
Tel. 888-531-7253
Fax 203-934-3405 Business Hours 8:30 - 5:00 PM M-F Eastern Time
Posted on Dec 13, 2011
How can i remove a switch cover to a dyson dc04
Hi, it's Cindy from Crucial Vacuum.
It is possible to replace the DC04 switch. Unplug your vacuum and remove the cyclonic assembly on your vacuum. Using a screwdriver, unscrew the switch cover. You may need to shimmy the switch cover off then the old switch is easily removed from its connectors and the new switch can be connected. Screw the cover back on and place the cyclonic assembly on and your done!
You can purchase direct your replacement switch from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc07-dc14-on-off-switch.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 26, 2014 | Dyson DC18 all floors Bagless Upright...
How do I seperate my dyson DC 24 for cleaning
To separate the clear bin from the cyclone pack, remove the bin from the machine and open the base as if you were emptying it. You can then separate the clear bin and cyclone pack using the silver catch on the rear of the cyclone pack.
You can wash the clear bin by rinsing it with cold water - always ensure it's totally dry before replacing it.
Dirt can be removed from the cyclone assembly using a soft brush or dusting cloth, but never attempt to wash this part or submerge it in water, as this could damage to the machine.
I hope this information is useful to you - if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Jan 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
My cyclone rake impeller dissintegrated... Nedd a new impeller...
Tel. 888-531-7253
Dec 13, 2011 | Vacuums
My Animal sounds like a jet engine, especially when I turn it off, it just winds down. I have washed the filter under the canister, is there another one that needs to be cleaned?
Hi, Barry. W/D here. I have just experienced this problem, and here's how to fix it.
  1. Remove the canister from the cyclone separator. One sign of clogging is debris on the filter located under the canister. If debris is present on the filter, clean it with soap and water, then dry thoroughly while you proceed to the next step.
  2. Looking up into the cyclones from the bottom, you will see the holes that correspond to each cyclone. I use a flexible grabber that is used to retrieve nuts and bolts. (It has a spring and thumb driven end that allows small jaws to open when the thumb end is pushed, and the jaws close when the pressure on the thumb drive is released). Pass the jaws end up into the hole(s), one at a time, opening the jaws as you clear the opening. Insert the grabber fully, and then release the jaws. Retract the grabber, and remove the debris captured by this method. Repeat as necessary. These grabbers are easily found at most hardware stores, and are inexpensive.
  3. Compressed air may aid in removing debris, or at least move it around to where it may be more easily grabbed.
  4. Lastly, you can disassemble the cyclone chambers to inspect and clean. The canister has three molded in lugs located internally behind the canister gasket. You will have to remove the gasket and carefully separate the halves. Use a sharpie and make match lines on your pieces as you separate them from here on in, to make reassembly easier. Once separated, you will have access to the screws that hold the cyclone assembly to it's base. You'll need a #20 torx bit to remove these. Once removed, remove any debris and clean all parts prior to reassembly.
  5. This should have you thoroughly cleaned. One other thing....dump the canister frequently; if you wait until you are at the full mark, you have probably gone too far.
  6. Hope that this was helpful. Best regards, W/D
Oct 05, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to remove and replace dyson DC07 frame assembly plastic housing, I have the new frame assembly, but can't figure out how to remove the old one.
As this procedure should only be carried out by a Dyson engineer, unfortunately we can't provide instructions on how to replace the casing of your DC07.
If you'd like to arrange for your cleaner to be serviced, you can do so by calling us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Oct 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
DC04 Handle broke on grey cyclone top. I have a new top and need to remove the yellow central cyclone cone from the old one in order to refit in the new one. How do I do that?
Unfortunately we can't supply instructions on how to dismantle the cyclone assembly. However if you wish to purchase a replacement cyclone assembly, you can do so via our online store:
http://www.dyson.co.uk/store/partsDetails.asp?part=ACC-DC04CYCLONE-STD&product=DC04-SY-STD-BC
Alternatively, if you'd prefer to discuss this directly with one of our experts, or to place an order over the phone, you can call us free on 08002980298. Our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Aug 20, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
We need to replace the Fan Blades on our Phillips Fan as they heve got very fragile and they are breaking up!
Yes-- This is the big disadvantage of this type of Vacuum--
Stones and sand wear heavily on that impeller turning a very high rate of speed.
This can be a tricky job----- depending on how long this fan has been on the motor shaft-- and if water has been passed thru this joint--
-- It will take a complete disassembly of the power section of this vacuum--
(I have seen a few times, when the impeller could be just hit a solid blow in the 'un-tightening direction, and the impeller spun right off- -- Very god, if you can get that response! :-) )
Most of the time one has to tear the motor apart, and get a solid grip on the armature (Clamping it firmly-- but gently in a vise -- and then beating on the impeller to remove it.
Naturally-- you would need to have the correct impeller ready to spin right back on the shaft-- for the old impeller will be ruined in removal. Be sure to put some 'never-seize' on the thread, to make it easier to remove NEXT time!
How old is the machine?
Ever consider trading it in on a new type of Vacuum?
Let us know if we can help more-
Mack B
Jan 27, 2011 | Philips Vacuums
I cant figure out how to remove the housing cover
Here's an excellent video showing you how to replace the clutch on a Dyson vacuum cleaner. It's a moderately difficult repair, but this video really helped me the first time I had to do this repair. I hope this helps you:
Thank you,
CJ
Apr 06, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
416 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
