Question about Palm TX Handheld
CONNECTION CANNOT BE ESTABLISHED
IM TRYING TO HOT SYN MY PALM WITH COMP AND IT SAYS THE CONNECTION BETWEEN YOUR DEVICE AND DESKTOP COULD NOT BE ESTABLISHED.. PLEASE HELP! wHY IS THIS HAPPENING
  • Joyless Mar 19, 2009
    HotSync Progress says Status Connecting
    User Name: is blank, but I do have my name down as the user and it is shown on the computer to sync with.
    My HotSync Manager is 4.1.0
    Do I need to update the HotSync Manager?
    I previously had the hot sync installed from my old Garman iQue3600 (Palm based).
  • Palm Master
  • 4,338 Answers
Check your USB ports with another device like a flash drive.
Reset your USB ports:
Here is what you can do to refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive.
If your USB ports are working, download and install the new version of Destop Manager and HotSync @
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1568,E=0000000000263321976,K=3877,Sxi=4,case=obj(32859)
reset your TX before you attempt to sync it with the PC after you download the new version of the software.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 13, 2009
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
SYN packet for established connection
Check the "TCP end timeout" setting. You can find in Policy -> Global
Properties -> Stateful Inspestion. FW-1 will take a connection out of
its established connections table after two FIN packets (one from each
party) or a RST packet + the time defined in this setting.
Have a great day,
Bhautesh
Feb 18, 2010 | Nokia IP 440 Firewall
When I try to hotsync I get a message telling me that connection could not be established. usb ports are ok. cable works. idid a soft reset. ray
It sounds like you have the settings wrong in the software on your desktop. If you are trying to hot sync it and your desktop software is set to sync it a different way other then by USB cable you will get that error message. Here is a link to a step by step guide of problems and solutions. Hope it helps.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/solutions/article/2630_en.html
Aug 15, 2009 | Palm Z22 Handheld
Connecting between handheld and desktop
Go to web site and get the user manual or try a google search.
Sep 15, 2017 | Palm M100
Palm Pilot: Connection for Hot Sync
Has synch worked before on this set up?
Jan 01, 2009 | Palm Z22 Handheld
I own a Palm Tungsten E2 when I go to hot sync I get an error message that states the connection between your device and desktop could be established please check your setup and try again
1. Go to your desktop program
2. Go to top and select HOTSYNCH
3. Select Set Up
4. Select the port your E2 is attached to
5. Theres more but I need to know how you are to this point or go to live tech support and ask for Just_Bobz
Sep 24, 2008 | Palm Tungsten E2 Handheld
Palm T/X synch problem
Make sure cable connected properly and Palm desktop software installed correctly. You may obtain latest palm desktop from link below http://kb.palm.com/wps/portal/kb/common/article/33529_en.html
Jul 07, 2008 | Palm m515 Handheld
Synching with desktop
Check to make sure the cable is securely plugged in to the USB socket on your computer, and the other end is securely plugged into the Palm device. Unplug them and plug them in again, don't just push on the ends -- if there is dust or something messing up the connection unplugging and plugging in again might shake it loose.
Mar 11, 2008 | Palm Tungsten E2 Handheld
Palm M515 hot sync problem
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Dec 20, 2007 | Palm m515 Handheld
Palm z22 usb cable connection problem
I have the same problem, but with TWO z22s. Both are about a week old, and both "talked" seamlessly to the computer. Suddenly neither does. Do not see anything wrong with USB port or cable. Uninstalled all PALM OS from desktop and reinstalled. Still no link.
Aug 22, 2007 | Palm Z22 Handheld
Palm TX Handheld Logo
348 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
