Question about Brookstone Pure-Ion UV Air Purifier
Green power light continually flashing. what does this mean?
Why does the blue light flash off and on continuosly"?"
Wayne,
I have attached a copy of the owner's manual. Page 6 in Safety section discusses why the light blinks. I hope it solves your blinking blue light issue.
PEACE http://www.sylvane.com/media/documents/products/airfree-onix-3000-air-purifier-owners-manual.pdf
May 24, 2014 | AirFree Onix 3000 Air Purifier
What does a green blinking light mean on my eco box? Also when cleaning the unit, which way does the metal plate face? Does the metal plate face towards the outside or the center of the unit. I'm...
When the green LED starts to blink, means that there is a bulb failure in the RCI module. It typically glows greenish blue when it working. Check the connector to see if it is seated properly, and also check the power connector for problems. I had a problem with the power connect not making a good contact and it caused the power to be intermittent. I was able to clean the connector with a can of electrical contact cleaner from Radio Shack to fix this problem. If you can't get the bulb to light, you will need a new RCI module.
As for the purification plate, the one that shaped like a tongue depressor, it does not matter which way it go back in to the unit. You should be able to get parts from your dealer or you can call the company at 800 989 2299. Hope this helps.
Jun 04, 2010 | Ecoquest Fresh Air Air Purifier
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
Ionizeair "check" red light is still on after cleaning
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Aug 19, 2009 | P3 International IonizAir P4620 Air...
Blue flashing light on lumipure air purifier
I read on another site to hold the power button down for 5 seconds. Dont know what the blue light is but this stopped it from flashing!
Jun 13, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Mar 22, 2009 | Hunter (30067) Air Purifier
Ionic Breeze - Press Blue - Press Geen button
The blue means the germicidal lamp is operating. Re: green light - Normal operation at all power levels involves a pre-programmed cycle of altering high and low air movement. Press the the green to override the regular power control setting and run the unit at maximum power for five minutes. Your previously selected power level will resume after the five minutes has elapsed.
Dec 11, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Hepa filter
The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
Aug 22, 2007 | Holmes Products HAP422-UC Air Purifier
Brookstone Pure-Ion UV Air Purifier Logo
Top Brookstone Air Purifiers Experts
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
