Question about Sewing Machines
I need an extension table (accessory box) for my New Home Memory Craft 6000? Is it possible to buy one?
This is an essential part of the machine but was missing when I bought this machine used. It a removable box that stores bobbins, presser feet and machine tools.
  • 323 Answers
SOURCE: new home 8000 memory craft embroidery machine
Locate a Janome dealer and have him order them for you. The power cord can be purchased from Radio Shack if the dealer doesn't have one.
sewman7
Posted on Jul 19, 2008
llkaygifts,
I just found this site...they have the manual for your machine...I think it like $12. Heres the link... http://www.sewusa.com/Sewing_Machine_Manuals/New_Home_Manuals/New_Home_8000.htm
Posted on Aug 05, 2008
  • 221 Answers
SOURCE: I need a new circuit board for a new home memory craft 6000
the board which you require will only be provided with the janome service center. still you can check out this link  http://www.sewingmachines.com.au/janome9000.html
for more details on any other require ment or contact this link to ghet them the required fboard for you.
Posted on Jan 08, 2009
  • 1126 Answers
SOURCE: Lost Instruction manual Memary Craft 6000
http://janome.com/index.cfm/Machines
http://janome.com/index.cfm/Machines/Professional/MC6600P#Machines_Overview
This is as close as I could get. Hope it helps.
Posted on Aug 19, 2009
SOURCE: oprater manual memory craft janomy sewing machine model no 6000
could you tell me how much the Memory craft 6000 is worth..My mother used it, but when she died, I have it, and would like to sell it...thanks, Dian
Posted on Nov 26, 2009
Where can I get directions for free motion quilting on my triptonic 2030. I am having trouble with the tension and bobbin stitches are awful.
For FMQ, make sure you have a darning or FMQ foot for your machine. You must use this foot because it is shorter than other presser feet so it does not press down on the fabric. You need to be able to move the fabric freely under the presser foot. When threading your machine, ALWAYS RAISE the presser foot so the thread will seat properly in the tension disk. The presser foot is ALWAYS lowered when FMQing or the tension will not work. To set the tension, test on some sample quilt sandwiches made with the same materials you will be quilting. Be sure to use a brand new quilting, microtex, or top stitch needle in your machine. Skipped stitches generally indicate the needle is dull, bent, or otherwise damaged. Test your stitching on the test sandwiches and adjust the top tension until the top and bobbin threads meet in the middle of the fabric (Increasing the top tension pulls the bobbin thread up. Loosening the top tension allows the bobbin thread to pull the top thread down.) Depending on your thread weight, you may need to adjust the bobbin tension, but do that ONLY if you cannot get the top thread to pull the bobbin thread up into the sandwich. (However, remember that if you adjust the bobbin case, it may not work properly when you go back to regular sewing.) I actually bought a separate bobbin case that I have adjusted only for FMQing on my machine and I use it only for that purpose.
Understanding Thread Tension on Your Sewing Machine
May 31, 2018 | Sewing Machines
Elgin model 2468 parts. I need a bobbin, and a foot for doing welt cords in autos.
Elgin 2468 Heavy Duty DeLuxe Sewing Machine Feet Bobbins Needles Parts
Your machine can use other presser feet as long a the shank is compatible with your machine. You may want to consider a zipper foot for sewing cording,:
Sewing Presser Feet
Sewing Machine Parts
May 20, 2018 | Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
I just purchased a Tacsew T111-155 sewing machine with a bobbin rewinder. Since the bobbin rewinder runs off the drive belt, how do you rewind the bobbin without the needle moving? Is there a button or a...
Hi Diane...you can wind bobbins while you are sewing your product, or you can wind them seperately. To wind them seperately, pull out the bobbin case, lift the presser feet up and lock them in the up position, undo the threading beyond the tension assembly. The takeup will create a birdsnest if you don;t pull the thread from it. Wind your bobbins, the re-thread your machine, insert your bobbin case, drop the presser feet, pick up the bobbin thread and sew away. If you need any other input, call me at 888-283-9640.
Robert with National Sewing Supply
Jan 01, 2011 | Sewing Machines
I bought a #7442 last Christmas and have not had a chance to use it until now. BRAND NEW, w/Carry Box and all. Anyway, my husband and I have spent ALL DAY trying to get it to work! We watched the DVD 5...
Not sure what brand of machine you have but generally after threading the bobbin the thread should be pulled out through a spring like device and by pulling on this thread and holding the bobbin case loosely in your hand, the bobbin case should turn clockwise inside the case. Clockwise is essential.
Then turn the machine by slowly by hand and let the needle go down and up once. Then pull up the end of the needle thread which should then lift the bobbin thread with it. Pull both through the back of the presser foot and start to sew. I hope.
Dec 08, 2010 | Sewing Machines
Every thing is missing
Go to www.managemyhome.com and you can download a free manual there. That will give you the directions to operate the machine as well as the Parts Numbers for any accessories you may want. I bought this same machine a few weeks ago. I have tested out almost every stitch on it, & almost the only 2 presser feet I have needed have been the Zigzag Foot (A) and the Satin Stitch Foot (F). Of course, if you want to do buttonholes or zippers, you will want hte Buttonhole Foot (R) and the Zipper Foot (E). Parts Numbers for ordering are listed for every part on page 6 of the manual. Good luck!
Jan 29, 2009 | Kenmore 19606 Computerized Sewing Machine
Sewing Machines Logo
44 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
