Question about JVC Sirius KD-LH300 CD Player
Volume/Power I was wondering if anyone knows why my deck would turn off at a certain volume i switched it from a 99 grand am to a 96 eclipse. You can txt me too my number is 612 432 3174
    Problem Solver:
  • 7 Answers
This could be a connection issue. are all wires tapes up with out touching each other? it could also be that you are trying to power too many speakers. u migth need a amplifier...
Posted on Mar 11, 2009
Connecting laptop to mixing deck!!
OK, try to increase the earphone socket volume by clicking on the 'speaker' icon on the task bar.
Sometimes it is not set to maximum volume in Windows' sound settings, to get full volume going to the mixing deck.
I know a DJ who used the same method to get very loud and clear sounds from his music collection at dances and parties.
Hope this helps!
Jul 11, 2010 | Dell Inspiron 1521 Notebook
I have an alpine iva-d105 and when I bring the volume up to 17 to 20 or so while playing a cd with lots of base or no base at all the hu shuts down and starts back up again an will do it again and again at...
It's common for the voltage source at the radio to be weak. Thin wiring and corroded connections create resistance in the power wiring, which results in a voltage drop when the deck's amplifier requires more current.
The easiest fix is to run a new power and ground wire directly to the battery from your radio. Depending on the length, some 14-gauge or 16-gauge speaker wire should do nicely. Connect the deck's black wire to your battery's negative terminal, and the yellow wire to the positive terminal. Put a 10-amp fuse on the wire near the positive terminal.
If your deck is wired to turn on and off through a key switch or accessory switch, then leave the deck's red wire connected as it is now; it doesn't require any significant current. Otherwise you can combine the red wire with the yellow wire and connect both to the positive terminal.
Let me know if you have any further questions
good luck
May 06, 2008 | Car Audio & Video
Subwoofer Turns Off when volume is turned up
check your earth from the amp i had same prob and the vibration broke earth connection once secured it was fine
Aug 24, 2009 | Pioneer TS-SWX310 Car Subwoofer
No sound
check your fuses you have an external amp for the speakers that is fused separately
May 16, 2009 | 1997 BMW 328
Losing power
mine does this too, I have the deck on my boat and on land the deck cuts out when a bass line hits or loud music comes in, cuts out at about 20 on the volume level, however, when on the water and the motor is running, my voltage is up to 14 vdc or so.. At this point, I can crank the deck up to 30-37, and it will scream , doesnt cut out or lose power just rocks. I have heard that kenwood decks are competition stereos and require 14-16vdc, but I have never found any proof of this. One thing you can do is order a battery from summitracing.com that runs higher than 12vdc. But then again im just speculating
Mar 05, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
Reciever turns off
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
Nov 24, 2008 | Onkyo TX-SR606 Receiver
Compatibility
this is a safey feature in your amp. you are drawing too much power for the amp to put out so i shuts off when the breaking point of the total rms calue is reached. i would suggest getting a more powerfull amp, a larger ground/powerwire combo, or a farad capacitor to balancethe powerin andthe power out.
Sep 04, 2007 | Eclipse EA3422 Car Audio Amplifier
Default volume too high
You can download the manual from the link below: http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds787_manual_e.pdf c. Power On Volume This sets a designated volume setting for the TX-DS787 to be set every time that the power is turned on. This prevents the TXDS787 from being turned on while it is set to an extremely high volume and suddenly output very loud sounds. For the absolute volume display method, this can be set between min and max. For the relative volume display method, this can be set between ?? and 18 decibels. If you do not mind having the TX-DS787 turned on with its current volume setting, set this to "Last." Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Onkyo TX-DS787 Receiver
Getting sound from speakers when heaphones are plugged in.
Hi,I know that the earphone jack usually has the switch built in, and often it takes a certain "End Shape" on the Headphone Plug to actually "Activate" it... I am wondering if this is not actually your problem? and maybe ya just gotta get the "Right One"? Sometimes I have seen the "Switch" in the Jack fail and cease to "Cut out" the speakers... which generally means replacement.
Aug 31, 2007 | Panasonic DVD-LA95 Portable DVD Player
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
JVC Sirius KD-LH300 CD Player Logo
53 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
