Question about Simer A5000 Ace In The Hole Battery Back Up Sump Pump System
System alert and alarm silence keeps blinking after reseting system
My 170 hummingbird beeps and wont stop even when i go through the menu and turn the alarm off on everything is this another piece of junk ????
Doesn't it show the cause of the alarm on screen? It might be the low voltage alarm which on some units can't be turned off, but can be adjusted to a lower voltage if it's alerting unnecessarily.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Jun 15, 2015 | Cars & Trucks
CO ALARM KEEPS GOING OFF FOR NO APPARENT REASON
Check the manufacturer's date on the alarm. There should be an expiration date, usually 5 years. You may have to buy a new unit.
Good Luck.
Aug 28, 2014 | Alert Safe-t-alert Co Alarm Direct Plug-in...
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
Mar 23, 2013 | First Alert SC9120B Smoke / CO Detector...
Alarm beeps every 5 mins. I have changed battery and problem still persists.
Tell me what brand your alarm is and I can help you with the beeping. Usually if you hit # it will silence the beeping for 24 hours. Something you can try is finding your main control box. Its usually located in the garage or in a closet. It is tan and 6 x6. First disconnect the battery inside the control box by jiggling off the black/red leeds. Then unplug the power supply. Wait five minutes. Reconnect the battery and plug in the control box. This is completely powering your system down and then repowering it up-essentially "re booting." If this does not correct the issue, give me the brand and I can further help you.
Nov 22, 2010 | Industrial Home Security Burglar Alarm...
CE flashing in the temp window of upright freezer I can silence the alarm by pushing the reset button but the red light blinks. Inside the freezer the indicator means operational error
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 08, 2010 | Frigidaire 16.7 cu. ft. Upright Freezer...
Alarm keeps going off and dont have key to deactivate how can I silence the alarm
Finbd the FOB that came with the car or go to the dealer for one. You won't be able to silence the alarm, since it's equipped with an internal immobiliser.
Aug 07, 2009 | Toyota Yaris Cars & Trucks
2003 Hyundai Elantra - diable alarm
YES!... with various system operating difference. Disconnecting the alarm does not disable it.. it only silences the alarm. You will still need the Keyless Entry System Remote to RESET the alarm to start the vehicle.
Jun 10, 2009 | Hyundai Motor 2003 Elantra
FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Feb 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Simer A5000 Ace In The Hole Battery Back Up Sump Pump System Logo
73 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Bill Boyd
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
