Question about Nintendo Wii Console
Cusor wont appear on screen after setup
Brand new wii, brand new batteries, everything appears to be setup correctly....now the "hand" cursor will not appear on screen...it worked thru initial setup but not now!!!!
  • Anonymous Mar 11, 2009
    The wii curor wont show on the screen. What do I do?
I had this problem too, and I found out what was wrong. I hope it's as easy of a fix for you as it was for me, the only thing is if the reason is the same. If your Wii sensor bar is not wireless, carefully check the wire for frays. Once I brought my Wii to my cousin's house and had the same problem you have. We did everything we could think of, then I checked the wire. It was frayed. I couldn't understand how it happened because we barely ever touched it, but we just replaced the Wii bar and everything was fine. Even if you can't see any frays on the outside of the wire, it's possible that the damage is on the inside of the wire. Try testing another wii bar on your system if this happens or if you don't find any visible frays. I hope this solves your problem. I know how frustrating this can be. Let me know if everything worked out!
Posted on Mar 11, 2009
Wii remote cursor hand not appearing on the screen
I am not sure but I had the same problem when I got a second remote hand set and my kids knew the answer. I first thing I would do is to ensure that you have new batteries in the handsets. Secondly there should be a small button inside the handset. I think that you need to push it to synchronize the handset to the Wii base station. I hope that helps
Nov 26, 2010 | Nintendo Wii Console
No cursor/hand appearing on Choose Language screen
Are you sure you have put that "bar" included in the box above your tv in the middle, and fully wired? Because that is what you need to be able to have your cursor on your tv screen when your wii is on. Stupid or not, also make sure the batteries are put in it the right way, that you get blue light flashing out.
May 24, 2010 | Nintendo Wii Console
My ******* wii remote wont work. It's synced and everything. I can enter the wii menu, but the hands wont show up on the screen. I am 4 ft. away from the sensor. I have no other infrared things and the...
youo may have a defective Wii remote, and you should take it somewhere like GameStop and have it looked at, or you should take it back to the store and exchange it for a new one.
Nov 14, 2009 | Nintendo Wii Remote Controller
Cursor hand will not show up
Make sure you do not block either the sensor bar or the sensor on the wiimotes. Check all your connections in the back escpecially the sensor bar. If everything is all set you said it worked for your new wii system so im assuming your old one has issues. try all these out and tell me how it works out
May 25, 2009 | Nintendo Wii Console
Cursor will not appear on screen
make sure your sensor bar is connected to the console! properly aligned in the centre of t.v! also reconect the controler by: open the sd flap on front, press red button, remove batt cover of remote and press the connect button! this will resync the remote! also check battery's!
Jan 04, 2009 | Nintendo Wii Console
Hand icon wont appear on the Wii main menu
Well, mabey your sensor bar settings are out of wack. You might have your sensor bar set to above TV but you actualy have it below. To fix it, I would move the sensor bar to the opposite position, go into settings and chanage the sensor bar settings to the way you want. then put the sensor bar back where you want it.
Dec 23, 2008 | Nintendo Wii Console
Wii cursor
try to resync the remotes.
Jun 27, 2008 | Nintendo Wii Console
Wii console...cursor doesnt appear on the screen but everything is sychronised and buttons on remotes work?
In the Wii settings make sure that the sensor bar setting is correct wheather it is top or bottom of tv. Then make sure the sensor bar is as far font as you can get it to give clear line of sight to the controller.
Apr 28, 2008 | Video Game Consoles & Games
Wii Cursor Does Not Appear
I had the problem where the cursor worked on the main menu screen, but disappeared once you entered any of the channels or a game. For me the problem was a faulty sensor bar. You can check if your sensor bar is working by focussing a digital camera on the bar as if you were taking a picture of it. In the viewfinder you should see 5 blue lights illuminated on both ends of the sensor bar. For me, only one side was illuminated. The sensor bar had to be replaced.
Dec 26, 2007 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
156 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
