Question about American Bath 60 Inch Windsor Cast Iron Clawfoot Bathtub by American bath Factory with 7...
Grid pattern showing through a cast iron bath tub less than a year old.
  • 102 Answers
Take digital photos and start the warranty process, it sounds like a poor enameling job.
Posted on Mar 11, 2009
I would like information on steps to remove bathtub and install pre fab shower
This is a fairly big job but can be done if you have the right tools and a little bit of time....... Depending on the existing tub material (cast iron,fiberglass, tin type ). You will want to remove faucet trim(handles,spout) first. Then the over flow plate on tub,as well as drain in the bottom (this will require a drain removal wrench or pair of needle nose pliers and screw driver, and some strong arms).After this is done remove tub unit , if the unit is a cast iron unit a good sledge hammer will work as you will need to break into halves to remove unless your trying to save tub and provided you can then get the unit out the door in one piece...... Caution, protect body and eyes in this process, flying pieces of cast iron can do some damage to body......cutting tub will take several blades and take quite a while to do......The next step depends on the location of faucet and if you are replacing the tub faucet or going to use the existing faucet.... I would recommend a new faucet because if this is going to be a shower only you may want to raise the faucets so they will be easy to operate without having to bend..Depending on the model pre-fab (two piece,three piece) unit you wish to install you may need to prep the drain to make sure it will fit your new installation. Let me explain... most tubs have the drain located at the right/left end of tub and the showers are located in the center of the unit thus leaving you to relocate the drain. If house is on slab it means a little jack hammering the concrete to provide this, if the floor is a conventional it means re-routing the drain to the center.......once all this is accomplished you are ready to install unit base,connecting drain. Next you need to get the faucet located to the right height or be able to get to the back side of the shower and remove the existing faucets and replace them after you install surround.....turn off water supply before removing faucet..... A sturdy surround will make for a less involved support system around shower area.Be sure to leave enough space between studs for faucet attachment. Sounds like a lot of work and it is but after its done you will have a great bath shower..... hope this was helpful.... sorry this only dealt with the plumbing aspects of the job......
Sep 05, 2011 | Home
I have an old cast iron, enamel coated tub. It has a tub stopper that you turn a lever to make the stopper go up and down. Problem is that in order for my shower to drain and not become a bath I had to...
I would consider replacing the trip waste with a newer still. That still has a lot more linkage then the newer one and that's way no one uses then anymore I not sure you can buy them now.
The main reason why I say replace it now is the linkage tends to collect a lot more debis such as long hire it will stop up continually.
Feb 01, 2011 | Home
How can i find the main water turn off; the cold water tap, for the bath, needs a new washer
if it is not in,under or right outside your house you can always shut it off at the water meter,usually located on the property line under a metal cover. use a crescent wrench or channel lock pliers. if more than one family is on this one meter, notify everyone involved about your repair problem and co-ordinate a time to turn off the water that is convenient for everyone.
Sep 16, 2010 | Whirlpool 67"x30" Cast Iron Claw Foot...
Water entering twist mechanism which closes K-7160 tub drain and dripping on outside of Kohler cast iron tub into basement below. Is the solution to tighten gasket on outside of tub or fix water backsplash...
If the water is entering through the overflow on the twist mech. then the gasket should be tightened and or adjusted. If possible feel around on the top of that fitting from the back side to rule out water leaking from other source, such as backsplash or faucet from escutcheons. It sounds like you have a pretty good idea of how to fix it. I hope this helps.
May 20, 2010 | Kohler CLEARFLO BATH DRAIN K-7160-TF-BV
12 year old fiberglass tub originally white, now
home depot sell a bath tub remodelation kit.
it cost about $40 .
May 12, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Cast-iorn tub to fiberglass shower kit not sealing
keep caulking or change to ceramic tile, or one piece shower units ,without seams
Mar 03, 2010 | Home
How to convert old tub to hot tub motor
what kind of tub? what material is it? if its porcelain and iron forget it unless you just want to buy portable over the side hanger type unit to drill the holes would be far too expensive
Aug 22, 2009 | Vintage Tub & Bath Home
What type of grids are the best and why, either porcelain over cast iron, or just cast iron.
The porcelain is easier to clean,and wont rust,but it can also be chipped off if dropped.Its really a personal choice after that.there is nothing wrong with the plain old cast iron ones.
Jun 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
Difference between acrylic and fiberglass
Acrylic is a solid sheet material that is heated and vacuum formed to the desired shape. It is then reinforced at the back with fiberglass to give it strength. It is a higher-end material, very durable and super easy to clean. Fiberglass is a material that adheres to a mold and then a gelcoat finish is sprayed onto it. The most common material used in tubs and showers and is the most economical. Cast iron tubs are forged and the finish is applied in powder form while the tub is hot causing the finish to melt onto the cast iron. Synthetic tubs are molded and then a gelcoat finish is applied like the fiberglass tubs.
Aug 27, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
American Bath 60 Inch Windsor Cast Iron Clawfoot Bathtub by American bath Factory with 7... Logo
107 people viewed this question
Top American Bath Home Experts
john h
Tom Chichester
Are you an American Bath Home Expert? Answer questions, earn points and help others
