Question about Genius VideoCAM Eye Web Camera
Webcam & headset not wkg on msn
Have a V58 Blue Sonic webcam & headset that will not allow me to activate it.
The program disc was downloaded and the camera takes still shots but will not activate when request to view.
MSN says it does not recognized and does not activate the request from the other person to view.
  • Weldon Dube'
    Weldon Dube' May 11, 2010
    See section C. Windows Live Messenger in the info below to setup the Audio & Video. Also send this to your family and friends so they have their computer setup properly. Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype. Each program has Options that have to be setup in order for the Audio and Video to function properly. A. Skype Setup: After downloading and installing Skype http://www.skype.com/intl/en-gb/download... ) set it up as follows: Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card. Then click on the Video Settings. The camera, if Installed Properly, it will come up and show a video picture. Then, on the bottom of the page click save. The camera and audio should function properly. Your friends and Family will now be able to see and hear you. B. Yahoo Setup: After downloading and installing Yahoo Messenger http://www.soft32.com/download_30.HTML ) set it up as follows: Go to Messenger at the top left and click on it. Next go down to Preferences and click on it. Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike. Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant" and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup. Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam. Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically". Then click OK and it should work. C. Windows Live Messenger:http://www.microsoft.com/downloads/detai... After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X. Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar". Next go to the Menu Bar on right side, click on " "Action." Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions. NOTE: Your audio and video should work. Enjoy. When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to. D. AIM (AOL) Messenger:http://dashboard.aim.com/aim On the VIM sign-in window, click on Edit. Then click on Settings Enhanced IM. Next click on Enhanced IM. Then click on Audio Video. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer. The Audi Video drop downs are Microphone Speaker Camera The audio and camera should function now. Additional information to use with VIM settings. Adjust Your Audio and Video Settings: In order to adjust your audio and video settings, please follow the steps given below: 1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button. 2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working Properly. Follow the on-screen prompts. Notes: The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts. images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the Picture-in-picture (PIP) display. After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
    Scholar:
  • 33 Answers
I have an Alba 5MP Laptop Webcam, and this is how I got mine to work, but it should still be the same. Hope it works! (And rate me if it does please) Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Posted on Aug 06, 2009
3 Suggested Answers
SOURCE: Wont work on Msn
Here is a tutorial follow it and ya should be all good. http://www.microsoft.com/windowsxp/using/windowsmessenger/ballew_video.mspx
Posted on Aug 20, 2007
yooperbud
  • 8637 Answers
SOURCE: vga webcam and headset
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
Posted on Jan 14, 2009
I have a usb webcam and i want to change it for manycam, what can i do?
You can't change your webcam but you can download the Manycam program and run your camera using the Manycam program.
Copy this site and paste it in your browser address bar and hit ENTER.
http://download.cnet.com/ManyCam-Virtual-Webcam/3000-2348_4-10593500.html?tag=mncol
to your web browser and paste it in the Address Bar and hit ENTER.
Then download the program and install it to start having fun with your camera and friends.
Manycam allows you to use your Webcam with multiple programs at the same time. Broadcast your
Webcam on MSN Messenger, Yahoo!, Skype, AIM, Paltalk, and Camfrog all simultaneously. Manycam
also allows you to add cool live CGI (computer generated special effects and graphics) to your
Webcam. Make it appear as if your face or hand is on fire with our "fire" effect.
Pretend you are underwater or make it look like it's snowing inside your house with the
Manycam underwater and snow effects. Add text, graphics, or your country's flag to your video
window.
ManyCam is the freeware tool for you if you use both CamFrog and ICQ, or any other video chat
program, and you want to use them simultaneously. It creates a "virtual" Webcam that
replicates your currently installed camera. It then lets multiple applications
access the video stream without conflict.
ManyCam is compatible with Yahoo, MSN, CamFrog, PalTalk, ICQ, Skype, YouTube, and more. Once
you've installed ManyCam, you need to set ManyCam as the primary input for program that you
want to use. ManyCam will automatically start when you activate your Webcam through that
program. The application includes a bunch of gimmicky features that let you change aspects of
the background and foreground. You can map a new pair of cartoon eyes over your face, and they
track pretty well to your movements, or you can show that your life is hell by replacing the
background with flames.
NOTE: There is an unfortunate toolbar that will install unless you opt out during setup, but
other than that ManyCam is worthy of a Webcam Oscar for cool and useful tech.
Hope this is of some help. Bud
Jun 30, 2010 | Logitech QuickCam Orbit AF Webcam
Toshiba satellite L505D-S6952 camera locked my another device
window.
Mar 26, 2010 | Toshiba PA3554U-1CAM Webcam
Quick cam pops up and it says the camera is busy. when i close all the programs it still says its busy
window.
Feb 16, 2010 | Logitech QuickCam Communicate Deluxe...
I have the Hercules Dualpix hd webcam and downloaded and installed the Webcam Station Evolution 3.2.2.1 and the Xtra Controller.When using,both of these pop up,but after a few seconds the picture...
window.
Jan 26, 2010 | Guillemot Hercules Dualpix HD 4780428...
Just downloaded my Genius Look 313, continuosly getting msg., " camera being run from another dvice" how do I fix this
window.
Jan 05, 2010 | Genius Look 313
When I use my webcam, I can see me but the person
uninstall current software
unplug webcam
download new software
http://www.microsoft.com/hardware/download/download.aspx?category=ICE&type=LifeCam&sku=68A-00001
configure to msn
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Dec 10, 2009 | Microsoft LifeCam VX-3000 Web Camera
We cant intall splitcam?
Try this program.
window.
Nov 12, 2009 | Microsoft LifeCam VX-3000 Web Camera
Webcam on my advent k1501 laptop says it's not working
window.
Oct 05, 2009 | Computers & Internet
How to activate webcam (msi U100)
you can activate that msi wind u 100 webcam when it is being installed on your system. You will be needing a driver installation source in order to use the device. the reason why you need these drivers, its because it allows the device to be recognized by the operating system .
you can download drivers for free at the manufacturers website.. :)
Hope this will help you out..
Pm me with your operating system and the model of your webcam if you want me to download the drivers for you..
Thank you :)
Aug 08, 2009 | MSI Wind U100-030US Laptop
Genius VideoCAM Eye Web Camera Logo
231 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
