Question about Sony Ericsson J230i Cellular Phone
Please tell me the trick to tune the FM radio without handsfree.
Hi I am in a trouble I have tried all the solutions but failed.
  • 36 Answers
Hi try for autusave the channels option wen u switch on the radio.
i hope ur problem will be rectified soon.
all the best
Posted on Mar 11, 2009
How can I listen to the radio without the head set?
Hi Arthur, unfortunately you can't as the wired headset acts as an antenna!
Since the FM radio uses the provided wired stereo headset as its antenna, before opening the application, connect the headset to your phone's the audio jack.
9.3.1 Opening the FM Radio
1. On the Home screen, touch
2. The first time you open FM radio, touch Auto tuning, which automatically scans for
available FM channels, saves them as presets, and plays the first FM channel
found.
May 01, 2016 | Huawei Cell Phones
Nktel model no k500 reset password
my nktel k500 china mobile (not ericsson) always don't get network and also FM not works, on activating the FM, a massage on the screen displays that "lnit fail, please retry!"
please provide me proper solution.
my email- shyamsparashar@gmail.com
Aug 02, 2010 | Ericsson Over The Ear Handsfree For K500i,...
Samsung f210, when i answer a call or make a call i can hear them talking but they can't hear me talking, also the fm radio player has never worked the fone has been like this from new i didnt get it fixed...
Hi,your samsung phone has a mouthpiece problem that needs to be changed.
On the other hand,Does your phone charges?because before your fm radio works, you will need to connect an handsfree device to it to enable your radio.
To make hings very much easier ,you can also use your handsfree to make your calls if eplying the other one will stress you out.try and see if it will work and get back to me if you can.take care.
Jan 19, 2010 | Samsung F210 Cellular Phone
Secret code to use fm in j120i without handsfree
you can't as handsfree is also aerial. it says in the UG that you need to plug in the headset to be able use the radio.
May 28, 2009 | Cell Phones
J230i Fm works without hands free 100%
Sony ericsson j230i Fm without handsfree working 100%
Jan 10, 2009 | Sony Ericsson J230i Cellular Phone
Nokia 5220 expressmusic FM radio always says off
I have the same problem and don't see a way to set the frequency of the stations if you can't set the radio to on...............
Nov 07, 2008 | Nokia 5220 XpressMusic Cellular Phone
FM Radio
The RDS (Radio Data System) FM radio is built-in and offers instant and easy access to FM radio channels in your phone. A handsfree or portable speaker set must be attached to the phone, as the wire works as an antenna for the radio. You can then choose to listen to the radio via the handsfree or the portable speakers, or through the speakers in the phone.
Jul 11, 2008 | Sony Ericsson K608i Cellular Phone
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Fm player
You can't initialize the FM radio without the handsfree attached because the phone uses the handsfree wire as an antenna. You can achieve this by building a special snap on to the phone that activates the pins on the port on the bottom of the phone...but it would be pointless since without the handsfree there would be no reception meaning you won't hear anything...just lot's of static.
Dec 12, 2007 | Sony Ericsson J230i Cellular Phone
Sony Ericsson J230i Cellular Phone Logo
67 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
