Question about HP DesignJet 5500PS InkJet Printer
Hp fax scan and prnter
My scanner need part so I can fix it by replace the part I need so who can I call for so I can get part for it
    Genius:
  • 2,120 Answers
Partsurfer.hp.com
Posted on Mar 12, 2009
Hp officejet 7410 will not fax or scan
Needs little bit technical skill level to do this activity:Open adf unit, remove flat bed glass, take out CCD unit, open bonnet of CCD, clean reflcted gasses with smooth cotton cloth or ear buds(no solvents requited) fix it back, clean glass both side, fix back all, try it..best of luck..Pl see the snaps for help:
Feb 04, 2012 | HP OfficeJet Office Equipment & Supplies
Unable to send, copy or send fax
Sounds like the scanner bulb is burnt out or it's not able to move the scanner sled.
It should be saying "scanner error" as well. (and I think you meant unable to scan, copy or send fax)
No fix unfortunately other than getting a replacement unit (which I believe now is the 8500 premiere)
If you need a replacement, your timing is good, they are $200 off right now, and selling for $299.
Your unit as it stands still makes a good printer and will receive faxes, and you CAN send a fax as long as you do it from the computer.
Feb 28, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
HP PRI
completely uninstall all software realated to this printer. disconnect your pc from the web. disable your anti virus and firewall then run your fresh install. if you are getting the diver/software from the web save it to your desktop and follow the first dsirections this should solve your problem
Mar 06, 2009 | HP LaserJet 2840 Printer
I cant scan!
Resolution : I
1 Scan using Windows Fax and Scan
Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  • Click New scan .
  • Click File , and then click Scan .
  • Option two: Scan using Paint
    1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
    2. Click Paint .
    3. Click File , and then click From Scanner or Camera .
    4. Click Scan .
    II nd issue :
    Problem :
    'An error occurred while communicating with scanning device' Message Displays in Windows Vista When Scanning
    Then refer to
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01290511&cc=us&lc=en&dlc=en&product=441125
    Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
    HP photosmart c7180 scanner failure
    you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
    good luck...
    L.C.
    Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
    No Scan Options Error Message
    Vista?
    Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
    When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
    1. Click the Start (c00845897.gif ) icon.
    2. Click All Programs .
    3. Click Windows Fax and Scanning .
    4. Click New Scan .
    5. Click File and then click Scan .
    Scanning with Paint
    1. Click Windows .
    3. Click Accessories .
    4. Click Paint .
    5. Click File and then click From Scanner or Camera .
    6. Click Scan .
    Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
    Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    HP DesignJet 5500PS InkJet Printer Logo
    32 people viewed this question
    Seeker5211
    Seeker5211
