Question about Sony VAIO V505BXP Notebook
I NEED A REPLACEMENT ADAPTOR FOR 2 DELL NOTEBOOKS. ONE IS AN INSPIRION 1500. BOTH ADAPTORS WERE INTERCHANGEABLE BETWEEN LAPTOPS. BOTH ALSO ARE BROKEN.
  • Lance Malone
    Lance Malone May 11, 2010
    You said 2 notebooks but only gave the model of one of them. What is the model of the other notebook?
Our dell inspirion 1525 keeps switching itself off when it is plugged into the mains electric. Also the battery does not hold it's charge. What could be the cause ? Thanks
Without looking at it I'd guess at it being the DC power jack (where you plug in the power adaptor). These are prone to wear and tear and are easily damaged. When your laptop is plugged in and is turned on, please 'wiggle' the power jack and see if your machine powers down and/or the charging light comes on. If any of the above happens, then it's your DC jack. These can be replaced.
Zahc
Jan 26, 2011 | Dell Inspiron 1525 Notebook
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
How to replace DC adaptor on a dell 1501
I can but i can't explain it on the system
May 20, 2010 | Dell Inspiron 1501 Notebook
Battery problem
replace the battery. this means batary life is over and needs to be replaced. also chheck the adaptor hooking to other notebook of some friend that it is charging the laptop properly or not. prob will be isolated weather the battery is to be replaced or the adaptor.
May 13, 2010 | Dell Inspiron 1525 Laptop Jet Black
Screenblinking blinking
yes replace ac adapter. light on ac adapter does not blink
Mar 07, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
BRightness FN control does not work. I tried control panel settings to adjust brightness but there is no slider. I am running Windows 7 on a Dell Inspirion 1501 laptop. Please help!
This looks to be a software issue. if the slider in the control panel is off, and it is not responding with the Fn key. then you should check the display adaptor in device manager. install the appropriate driver if needed.
Feb 25, 2010 | Dell Inspiron 1501 Notebook
Dear Sir, My Dell Inspiron 6400 have problem with power unable to switch on as when Adaptor is plug into my computer. senario: 1)Try to unplug and adaptor indicator is lights on. 2) when plug in into...
Hi your AC adaptor might be the problem. I repaired about 7 adaptor charger and I can you that this is the problem. Lot of time this unit is always be drop and the enternal parts such as transformer wiring solder to a little board are all broken off and no connection to the transformer or to the board. Just buy or order it to dell web site and cost is depending to the model of your laptop. I believe the cost is under $100.00.
Aug 22, 2009 | Dell Inspiron E1505 Notebook
Dell 600m Computer won't power with adaptor connected
Bad motherboard, unfortunately. Seen it before as a Dell tech.
Jun 29, 2009 | Dell Inspiron 600M Notebook
Power adaptor is not detected
AC Adapter Error Message Occurs
Here is what you need!!! Click on the Above Link. Follow Each and Every Step.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 22, 2009 | Dell Inspiron E1405 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Sony VAIO V505BXP Notebook Logo
27 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
