Question about Philips DVP642 DVD Player
Philips DVP642/37 Plays breifly then ejects DVD and shuts off.
Our Philips DVP642/37 DVD player has worked great for some time. No video or audio issues. However it now will only play a brief portion of any DVD inserted into it. It doesn't seem to have any trouble loading (it may be just bit slower to load than usual). Then it plays the DVD intro like the copyright info and such and then quits playing and promptly ejects the DVD and shuts off.
Each time you try to load the DVD it plays for a shorter and shorter length of time until finally it immediately shuts down on each attempt.
I can't think it is the laser lens being dirty which we did clean with no effect. The picture quality and audio remain great until the unit just shuts off. When I had it apart, I did notice what seemed an unlikely amount of heat coming off what looks to be the power supply. I say it seemed unlikely just because it had only been on for a very brief time and it was already noticeably warmer there. That could be normal though.
Please tell me which is the component most likely to cause such an issue. Power supply going bad, over heating? Also since it is already past warranty and I have experience replacing computer parts, I would like to try my hand at fixing it myself so a recommendation as to where I might find the needed parts would be great too. Thanks
Vanessa
  • 2 more comments
  • vmj6 Mar 11, 2009
    Thank you for your response. We have a number of DVDs we play often like workout and kids movies. They are compatible with this DVD player, have always played before. Yes we have tried several of these DVDs, all known to work before, not working now. Your right about the heat sink. After posting my question I went back and looked at the PCB and say that the area that seemed warm did indeed look like a mini version of the heat sink in my PC. Yes we tried running the player with the player open with out any better outcome. So I guess over heating isn't the issue.
    It just seems strange that when it has been off for some time it runs for a bit longer before shutting down. But each succesive attempt results in shorter and shorter run times.
  • vmj6 Mar 11, 2009
    Also, I should note that the front display continues to work fine. There are no clicking or grinding noises from the gears where the DVD sits when spinning or when the tray is opening and closing.
  • vmj6 Mar 12, 2009
    No it is not a copyrighted issue these are not copied DVDs. Please read the rest of the post before making suggestions and you will see that these are DVDs we have been using just fine up till now. We have tried many DVDs and have verified that they are still playable in our other player. Also, the problem described above only effects video. When we ran the cleaning disk it worked great and played the audio tracks no problem. The player also has no problem playing music CDs still. It only ejects and shuts down when we try to play a movie or other disk with video on it.
  • vmj6 Mar 12, 2009
    Likah says "maybe you have defective pick up laser lens, or defective flex ribbon
    wire, this parts need manually replace first the flex ribbon wire".
    Thanks, I am willing to try replacing these. Where might I look for the parts I need? Are there retail sources for these items?
    Also someone else said it might be the ic. What is that is dumb people speak? I need a littler bit clearer an idea of what I am looking for if I am going to order parts.
  • Philips Master
  • 19,396 Answers
It sounds like your DVD firmware need to be reinstalled. If it was a lens problem the unit won't shut down, and usually does not read from start.
Unfortunately Phinlips does not distribute firmware for this model (see: Where can I find the firmware upgrade?) The only source to
get the firmware reinstalled is an authorized philips repairer.
The guys posting here also say that they have the firmware download for your model, I would ensure by calling Philips before risking to damage the unit by insttalling the wrong Firmware.
Posted on Mar 12, 2009
    Sergeant:
  • 254 Answers
Faulty lens and circuit board.reparing cost will benear to new dvd .getting new is advisable in this case.as lens replacement and board reparing internally is a costly issue.
  • 98 Answers
Replace the dvd drive its self just like u would on a computer.go to the local computer nerd store. they allways have hard to find stuff. or for real look on e bay
    Brigadier General:
  • 8,619 Answers
Hi!
Check for the capacitors on the power supply, they might be swollen and are causing this issue.
Posted on Mar 11, 2009
    Master:
  • 763 Answers
Mam how about looking at the settings of the system of your dvd and configure the issue from not loading well or you can refer the manual of it. Sometimes it occurs on the dvd itself
thank you for using fixya
CHARCOIS
  • 790 Answers
Hi
this is not power supply issue this is pick ups issue! maybe you have defective pick up laser lens, or defective flex ribbon wire, this parts need manually replace first the flex ribbon wire
Thanks!
    Brigadier General:
  • 5,158 Answers
Sounds like copyright issues... are these recorded dvd's ?
    Sergeant:
    Champion:
  • 435 Answers
Hi, Did if you think overheating is a problem, try running it in open and see if it plays for little longer.
Power units normally get heated up. To compensate it, heat sinks are used in them.
So, I think overheating might not be a problem.
Did you try with different DVDs? are you sure you are using proper DVD format for playing?
Do you remember how this problem started all of a sudden?
    Genius:
  • 1,847 Answers
This is issue with the ic, that need to bre replaced will let you know the part no#.
  • Legin Varghese
    Legin Varghese Mar 11, 2009
    Before making any changes try cleaning lens head with the lens cleaner CD. This many a times resolves the issue...Kevin
While playing an avi converted to dvd format mpeg2 it plays and for alittle then the audio stops vedio is still good but no audio
change another kind of converter.
Video Download Studio can help you with this.
get a free version from http://www.downloadvideos-convert.com/download-videos-music
hope it can help you more or less!
Mar 07, 2010 | Philips DVP642 DVD Player
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Using DVD+R i can burn an audio/video which plays
Tha's because not all dvd players can read DVD R+. Get a DVD R- and you will see how nice you can watch the videos in your DVD Player.
Aug 15, 2009 | Lite On SOHW - 1633S (show1633sbk)...
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
DVDS stuck in overhead DVD player
the motor will not be strong enough to eject. you can try the emergency eject hole with a paper clip . just push straight in and the gears will began to turn so push straight in a couple of times and it should began to eject.
Dec 13, 2008 | Jensen 8.5'' Overhead DVD Player Package...
Vcr only plays in black and white
Hi Ryana,
Check if the recorder is set to output in 'S-Video' or 'SuperVideo' mode, if your TV doesn't understand S-Video you'll get a grainy B&W picture. The VCR should be set to output in PAL for the UK and most of Europe.
Hope this helps
Andy
Jun 26, 2008 | Philips DVP620VR DVD Player/VCR
Phillips 6500 home theater system
Turn the power off, and then unplug the home theater from the wall outlet. Plug it back in after about 30 seconds, and turn it back on. If it still won't eject, then the HTS needs repair. Philips will replace it if it is still in warranty.
Feb 23, 2008 | Philips HTS-6500/37 System
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Philips DVP642 DVD Player Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
