Tv does not have picture
When I turn it on thre is on picture but the screan has static when I pushthe menu botton it shows it then i go through it sometimes the picture comes but sometimes not when I turn it off and after a while i turn it on there is no picutre again if i let the tv on the picture comes after five or so minutes could you please tell me what is the problem thanks
  • 790 Answers
Hi
this is horizontal power section issue... maybe you have leak flyback or leak capacitors...
Thanks!
Posted on Mar 11, 2009
TV has static but no picture. When I turn on the TV, I hear 2 clicks and static. Pushing the power button again, static stops and red LED light turns on. After 15 min. TV automatically shuts off.
Check your antenna is plugged in the right place.
Switch TV on then goto it's menu setting, if the menu appears then at least you know the screen works.
As a test, plug in a DVD player to one of the HDMI ports and try to play something. Make sure you select the proper input source from the source menu and see if you get a picture.
If you do then it narrows the problem down.
Next, from the menu, select TV source to see if picture comes.
There are a number of other sequences depending on what decoder or Viewer box you have, if it's just Freeview antenna then you may have a problem with that.
Make sure you've done the auto tune procedures too.....
Oct 11, 2016 | Televison & Video
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
Power botton blinks and there is no picture
Unplug the tv for 1 minute plug it back in, turn it on, if the button still blinks and the menu does not come up the tv will need to be serviced. All tv's should see a menu come up when the menu button is pushed.
May 06, 2010 | Toshiba 65HX81 65" Rear Projection...
Sylvania MTS/SAP TV. I don't have a remote I accidentally hit the ''menu'' button on the front. Now I can't get the TV to show anything but static -- like there is no signal coming in from receiver...
I accidentally hit the ''menu'' button on the front. Now I can't get the TV to show anything but static -- like there is no signal coming in from receiver (either through input jacks on front or on rear. Menu gives various options, but none of them gets me back to being able to see the picture.
Apr 07, 2010 | Sylvania SRT2232S 32" TV
Bush tv 20" lcd tv LCDS20TV006/A - blue screen no picture availab
DOES THE MENU SCREEN COME UP? IF YES TRY ANOTHER INPUT. A BLUE SCREEN IS USUALLY INDICATIVE OF THE SET NOT SEEING A VIDEO SIGNAL.
Apr 10, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
Oct 22, 2008 | Westinghouse LTV-46w1 HD 46 in. LCD...
When I turn on the TV the screen has static
Static usually means that the tuner is not working. Chack all of your cable connections first. As a quick test of the tuner itself, remove the cable from the exterior antenna connection and insert a small paper clip. That will act like an antenna and if you scan for channels, something should be seen. If not, then you probably have a bad tuner or have lost the source power for the tuner.
Dan
May 07, 2008 | Toshiba 50H81 50" Rear Projection...
Mitsubishi CS26301 27" TV
Have you tried flipping the pictures so you can troubleshoot it from the larger screen?
Feb 16, 2007 | Mitsubishi WT-42315 42" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
