Question about Pioneer GM-7300M Car Audio Amplifier
I have a pioneer GM-D7400M and the front blue light is flashing.
What does this mean?
    Problem Solver:
  • 9 Answers
The list number
Posted on Mar 11, 2009
Power light flashing
This means it is blown. Whenever the power light flashes on any amp it is blown or something else is wrong with it. Most likely its blown. You can blow am amp by hooking it up to a powerful sub and blaring it, or just overheating it. Hope this helps. This can usually be fixed as well
May 07, 2013 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
I have a pioneer gm-354 amp and the power indicater light on the front has changed from solid to flashing and no sound from the amp to the subwoofer it used to power any idea's
If it is flashing it went into the protect mode.Check that a speaker wire hasn,t come off, Or that the ground cable conection is good end all other hook up wires to it.
Oct 27, 2012 | Pioneer GM-X354 Car Audio Amplifier
The blue light on my gm-6400f amp mean
Judging by your English literary skills (ebonics?) I doubt that you would "unnerstan" any possible solution to whatever you may be "axing".
My advice is to go back to school, learn to construct an intelligible sentence, and then "ax" us again. Gud luk.
Jun 21, 2012 | Pioneer GM-6400F 4-channel Car Amplifier -...
I have a pioneer gm x334 car amplifier and the power light keeps flashing instead of staying steady. what does that mean?
make sure remote wire is good and tight, also make sure the ground has a solid connection.
If this helps please leave me a rating, thanks.
Jul 07, 2011 | Pioneer GM-X334 Car Audio Amplifier
Have hooked up al conections properly acording to diagams but amp will not pwer up. tested wire conections and i am getting juice to the amp but still no responce fuse are good amp is brand new out the box...
If this is new out of box make sure you have 12volts to the amp turn on wire. You should have constant 12volt + to the battery terminal 12volt- to the ground and 12volt + from the head unit (radio) to the amp The turn on wire on most car stereos is a thin blue wire. run this wire to the amp's terminal and when you turn on the radio the amp should turn on.
Sep 29, 2010 | Pioneer GM-D7400M Car Audio Amplifier
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
How to install car stereo with an amplifier and equalizer
power wire from batt fused to positive on amp .earth wire eg - to bare metal in car with bolt or screw. remote wire from amp to remote wire on back of head unit mostly blue wire it tells amp when to turn on then you need a set of rca cables to send sound from head unit to amp they go in subout if you wanna use sub or rear or front out for full sound best thing is to buy amp kit cheaper most the time and all you need there hope this helps
Oct 23, 2009 | Pioneer GM-D7400M Car Audio Amplifier
Pioneer GM-D7400M Amplifier Flashing
sent it to service center because the problem is inside the amp -sometimes electronics component failed by heat or bad ventilation or poor design work
Apr 14, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Pioneer GM-D7400M power light keeps flashing?
ur rcas could b round the wrong way you might have a weak earth aswll
Mar 24, 2009 | Pioneer GM-D7400M Car Audio Amplifier
Pioneer GM-7300M Car Audio Amplifier Logo
683 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
