Question about Energizer ER PRO1400 (ER-PRO1400) UPS System
Where can I get service for this unit?
Change batteries, tune-up like a motor vehicle, etc., etc.
    New Friend:
  • 37 Answers
You can try this asia systems technologies look for our sale person william +65 65478990
Posted on Mar 24, 2009
I have a 2001 pontiac montana and am trying to figure out how to change the starter.
STARTER REPLACEMENT (ENGINE ELECTRICAL) Document ID# 688149 Starter Replacement
Removal Procedure
Important: This vehicle uses the PG260 F1 starter motor. The starter motor is serviced only as a complete unit.
  1. Disconnect the battery ground (negative) cable from the battery. Refer to Battery Negative Cable Disconnection and Connection.
  2. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  3. Remove the starter motor BAT terminal nut and electrical leads.
  4. Remove the starter motor S terminal nut and electrical lead.
  5. Remove the torque converter cover. Refer to Torque Converter Cover Replacement in Automatic Transaxle - 4T65-E.
  6. Remove the starter motor bolts.
  7. Remove the starter motor.
Installation Procedure
  1. Install the starter motor.
  2. Notice: Refer to Fastener Notice in Cautions and Notices.
  3. Install the starter motor bolts.Tighten:
    Tighten the starter motor bolts to 47 [n-m] (35 lb ft).
  4. Install the torque converter cover. Refer to Torque Converter Cover Replacement in Automatic Transaxle - 4T65-E.
  5. Install the starter motor S terminal electrical lead and nut. Tighten:
    Tighten the starter motor solenoid S terminal nut to 3 [n-m] (27 lb in).
  6. Install the starter motor BAT terminal electrical leads and nut. Tighten:
    Tighten the starter motor solenoid BAT terminal nut to 10 [n-m] (89 lb in).
  7. Lower the vehicle.
  8. Install the battery ground (negative) cable to the battery. Refer to Battery Negative Cable Disconnection and Connection.
Aug 05, 2016 | 2001 Pontiac Montana
1993 excel is idling rough and stalls when I take my foot off the gas to apply the break at stop lights.
you need to do a tune up-change spark plugs ,fuel filter,air filter-and run some fuel injector cleaner through it -cheers denny
Nov 05, 2013 | Hyundai Motor 1993 Excel
I just bough an Oldsmobile silhouette 1999 and I would like to know what kind of service it needs, I mean oil change etc.
oil changes should be done about 2,000 miles(5,000 kil),tune-ups about 50-60,000 kil,tranny service about every 80,000kil,if you go to a library you should be able to get a book for your vehicle that will have service intervals in it that you can copy.
May 19, 2011 | 1999 Oldsmobile Silhouette
My 1990 probe ls says service check on the systems monitor. what does that mean.
next service (oil change/ tire rotations etc. )of your vehicle is due already or you need some tune ups.
Jan 13, 2011 | 1990 Ford Probe
Where is my starter and how do I change my starter?
2000 Hyundai Elantra 2.0L MFI DOHC 4cylRemoval & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Speedometer and shift control cables Starter electrical connectors Starter motor
    Fig. Exploded view of the starter-XG 300 and XG 350
To install:
  1. Install or connect the following:
    Starter motor and torque the bolts to 25 ft. lbs. (34 Nm) Starter electrical connectors Speedometer and shift control cables Negative battery cable
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    Negative battery cable Air intake assembly Speedometer cable Shift cable Starter wiring connectors Starter motor
To install:
    Starter motor and torque the bolts to 20-25 ft. lbs. (26-33 Nm) Starter wiring connectors and torque the battery cable nut to 88-140 inch lbs. (10-16 Nm) Shift cable Speedometer cable Air intake assembly Negative battery cable
To install:
To install:
    Starter motor and torque the bolts to 25 ft. lbs. (34 Nm) Starter electrical connectors Speedometer and shift control cables Negative battery cable.
All Others
    Negative battery cable and wait at least 3 minutes Speedometer cable and shift cable from the transaxle Starter motor wiring Starter motor bolts and the starter
To install:
  1. Installation is the reverse of removal. Tighten motor retainers to 20-25 ft. lbs. (27-34 Nm).
Hope helps (remember rated this).
Jul 14, 2010 | 2000 Hyundai Elantra
Just aquired A Ford Mercury Villager 1998 any suggestions as to stores for spares ie servicing Brake Pads, etc
On the villagers the front motor mount alot of the time is bad on these vehicles.Change the oil every 3,000 miles.Also check the air cleaner and the battery terminals and make sure they are clean if not clean them with like some 100 -150 grit sandpaper on the battery cables the positive and negative wires and also clean the battery post where the cables hook up to.
Apr 01, 2010 | 2000 Mercury Villager
How much for a 10000 mile service on a 2003 audi a6 2.7t
If you take your car in for a 10000 k checkup they will check all fluids, tranny, rear end/front drive, washer, oil, radiator, etc. They will check all hoses and lines(vacuum). They will check all electrical and electronic components. They will check all operational functions, heater, AC, wipers...etc. In the long run it could cost you well into $600-$800 dollars.....that you don't have to spend. If your vehicle is running well and your satisfied with it, than the only thing you have to do is maintain it with an occasional oil change and tune up. Believe me, I've been working on cars, trucks, heavy equipment etc for forty five years. Save your money, especially nowadays and change your oil for 30 bucks, get a tune-up for another 50-100 bucks and keep the rest in your pocket, Thank you, Dana
Jan 20, 2010 | 2003 Audi A6
XM radio tunes to random station when turned on
There is an internal battery to hold the station and presets. It is probably no good. Either that or there is something very wrong with the unit.
Here is what I recommend. Call XM. Tell them your receiver is not longer functioning correctly and that you are thinking about canceling your service because you don't have a receiver. They will then offer you a receiver because they don't make much money on them, the make their money on the service.
that's how you get a new free satilite radio.
Dec 24, 2009 | XM Radio (XMP6000)
Change my front wipers motor
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Sep 30, 2009 | 2001 Hyundai Accent
Maintenance
Hero Honda Passion is a four stroke engine with Japanese technology. Usually this bike gives good mileage and apart from this the engine is very smooth with small valves which take part in combustion. Service after every 4000Kms is compulsory and at the time of servicing the engine it has to be tuned.Apart from such services personally you have to do this services : 1) Weekly water service using shampoo. 2) Check the battery terminals every week and clean them with warm water. 3)Use shining cloth for cleaning the painiting surfaces. 4)Check the blow as per the requirement (Every week). 5)Check the break linings every two months. 6) Cover the vehicle when not is use to protect from dust,
Nov 10, 2008 | 2006 Hero Honda Passion Plus
Energizer ER PRO1400 (ER-PRO1400) UPS System Logo
52 people viewed this question
Top Energizer Computers & Internet Experts
Tom Chichester
Michel Laprise Sr
Are you an Energizer Computer and Internet Expert? Answer questions, earn points and help others
